Old 04-04-2019, 10:55 AM   #1
fastalkintn's Avatar
12,000 lbs with 6.2 F-250
Iím thinking about trading for a F-250 4x4 6.2 with 4.10 gears either loaded XLT or lariat. We will eventually be upgrading to a 5th wheel. The one we really like has a gvwr of 12,000.
I would love to hear input from folks that tow weights close to that with a similar truck.
Performance, power, mpg... that kind of thing.
Thanks in advance for your help.
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
fastalkintn is offline   Reply With Quote
Old 04-04-2019, 11:00 AM   #2
I have a 2016 F250 with the 6.2L gas and the 4.30 rear. Our camper is close to 8,000lbs loaded out. I only have a few thousand miles towing (bought it in Sept of 2018) but it is effortless. Compared to my previous TV (2011 F150 EB) it is very smooth and very stable.
Hope this helps.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 04-04-2019, 11:16 AM   #3
Denver To Yuma In 90 Days
I tow a 9500-pound (loaded) 5'ver with a 2015 Chevy 2500HD gasser with the 4.10 rear end...
I personally feel that 10,000-pounds is the limit to be comfortable.
I was towing at 9800-pounds before I left Denver a year ago, but have shed a lot of weight from the 5'ver (that is what happens when you go through a divorce )
JohnD10 is offline   Reply With Quote
Old 04-04-2019, 07:27 PM   #4
Thanks to you both for the input
2017 Salem 27RKSS
Old 04-04-2019, 08:53 PM   #5
Weíve been towing our Keystone Sprinter 5th wheel (12,750 GVWR) with a 2017 F250 6.2 gasser with 3.73 gears. About 4,000 miles so far. I havenít weighed the trailer but the cargo capacity is over 3000# and I donít think we carry nearly that much so, until I weigh it loaded, I figure itís about 12k. The actual loaded pin weight is just a fuzz under 2000#. (I used a Sherline type scale.)
Itís borderline, but not over payload or towing limits. With 4.10 gears you should be good. Driving is comfortable.
We have gone from Pittsburgh to Myrtle Beach three times now (both I77 route and I95 route) and get right around 8 mpg towing. It ainít the Rockies, but itís not flat. It will drop to 3rd gear climbing some hills so the engine will spin pretty fast. Some people donít think thatís good, but they are designed to do that. If you donít like the engine spinning fast, get a diesel. If you get a diesel, get a 1 ton.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 04-04-2019, 09:00 PM   #6
I pulled close to 10k with two different gas engines and two different Diesel engines neither diesel got more than 10 towing usually 9 ish both gas engines got around 8 ish. Every engine has kicked into lower gear climbing long grades. The 6.2 probably has more hp and torque than 90% of all 2010 or older diesel trucks
moose074 is offline   Reply With Quote
Old 04-04-2019, 10:09 PM   #7
'19 F250 CC 4X4 6.2's come standard with 3.83's and are rated to tow 12,500 pounds. The only optional gear is 4.30's which raises the towing capacity to 15K. The 4.30's aren't as steep as they sound as 5th and 6th gears are both overdrive. Search for the 4.30's and you'll be much happier.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2 4.30
woo10-210 is offline   Reply With Quote
Old 04-04-2019, 11:33 PM   #8
You should look up the towing specks fleet.ford.com
You need to put in the year, and there are several specifics, that make a big difference in what the towing capacity is.
My 2017 F250 5th wheel limit is 14,000.
I’d like to report how it pulls the 5th wheel, but we haven’t picked it up yet!
I’ve pulled 2 smaller trailers, both very easy. I get 16 mpg towing, and 18 mpg reg.
2017 F250 4x4 6.7 power stroke v8 diesel
2019 Chaparral 336TSIK
Teresa CAL is offline   Reply With Quote
Old 04-05-2019, 12:29 AM   #9
clarkbre's Avatar
Coming from an '11 Ecoboost with a 3.55 rear to a '16 6.2 with a 3.73, I would say the 4.30 is a must and you'd be fine. The handling of the F250 is awesome and the power of the 6.2 (it must spin up...think 3500+ RPM is good) is really good as well. Our trailer is 7,500 total and the 6.2/3.73 is well matched for it. Any more, I'd want more grunt in the gearing.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 04-05-2019, 05:34 AM   #10
Consider the F350
I just got an F 350 gas 4.3 axles, changed my order from the 250. Def play around with the online builder on the web site. F 350 comes with beefier Dana axles / and tranny, and beefier springs so you dont need to add those 4x4/ camper packages that in some cases basically add stickers. i can give more / better details if you want.
2019 Cruiser Stryker 2613
2019 F 350 6.2 CCSB 4.3
14k Equalizer
Deanm is offline   Reply With Quote
