Old 08-28-2015, 02:06 PM   #11
I have a Superflow MV 50. Got it from Amazon.ca Just looked at Amazon.com and it's there also. I also carry a 110 volt compressor in the 5er.
Pipeman is offline   Reply With Quote
Old 08-28-2015, 02:43 PM   #12
air compressor
Originally Posted by Lefty59 View Post
We use one of these: VIAIR Corporation - 400P Compressor (P/N 40043)
It pumps my RV load rated E tires up to 80 psi without any problems. I've used it once on the F350 tires (same psi as yours) with no problems too.
It might be a little pricey...but it works very well, is compact, quiet and very easy to use!
Only thing I wish it had was a longer set of cables for hooking it to the battery. I figure I can extend its reach though using my jumper cables if need be. I also got a second air hose (25 ft extension) so that I can reach the RV tires without unhooking if needed...but it can also be hooked to the RV battery as another method to extend the reach.
I have one it works great.
bear11 is offline   Reply With Quote
Old 08-28-2015, 03:28 PM   #13
I have a Black and Decker AS1500 cordless compressor and inflator, $60 with free shipping from amazon. It says on the box that it's good for 120psi. The most I us it for is 50psi for my bicycle tires. You can dial in the desired psi, and it will stop automatically at that pressure.
johntaylor is offline   Reply With Quote
Old 08-28-2015, 04:58 PM   #14
12v = frustration
I finally gave up on the 12v air compressors. I bought a pancake at Harbor Freight. I always carry my generator anyway... no more frustrations!
2016 Vibe 268RKS
2015 Chev 2500HD
Mewcasa is offline   Reply With Quote
Old 08-28-2015, 07:29 PM   #15
satdog01's Avatar
Has anyone used the Jumpstart which has a built in compressor that runs up to 150 psi? I notice both Costco and Sam's carries the unit for $60. Unit had a fairly heavy weighty battery in it. Guessing a lawn tractor or motorcycle battery.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, Ď15 = 52, Ď16 = 77, Ď17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 08-28-2015, 08:08 PM   #16
Who Dares, Wins
doc73's Avatar
Yeah, plan on sitting a long time to wait for them to get to pressure...
We have a blue hawk 2 gallon 120v one. I also have given up on the 12v ones. I generally carry a geni with me or will have 120 when I get to the campground.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-28-2015, 08:40 PM   #17
Boso's Avatar
Compressor
Harbor freight 150 psi 12v with 2 year warranty 69.00 will reach anywhere on RV or truck battery clamps quick and powerful compact with bag and all asseccories size of a football maybe little bigger
Boso is offline   Reply With Quote
Old 08-28-2015, 10:21 PM   #18
Vince and Charlette's Avatar
I bought the Viair 450P. Yes, it's a bit pricy at over $200, but it's built like a tank, all metal, stainless on the outside, sits on a diamond pattern vibration pad, comes with a 35' hose and a 12' DC power cord, large pressure gage, squeeze-trigger nozzle, all in a rugged canvas zippered bag. Pressures up to 150 psi. If you are serious, this blows away the competition...no pun intended.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 08-28-2015, 11:23 PM   #19
HONDAMAN174's Avatar
I went an opposite direction. Sometime I travel with genny, sometimes not. Ran a 1000w inverter under the backseat of the crew cab and ran 4 ga to it. Bought 120v craftsman for about 80$ 6 amps 1.75 cfm. Doesn't take too long to pump up my d rated tires from 40 to 60 at all. Maybe 90 seconds each. To get to rv tired I just pull out extension cord out of trailer. I am about to purchase 1/2 electric impact from harbor freight and leave my cordless impact at home so I don't have to worry if I have a charged battery or not. Inverter powers my metro vac (4hp) well also.
I didn't look extremely long for a 12v because of low air volume. Did pick up a economically challanged unit for when it comes time to blow water out of lines.
Just glad to get away
12 volt
