08-27-2015, 07:19 AM
12 volt air compressor's
Upon retirement the wife and I plan on going cross country and in pre planning I'm trying to put together my emergency repair kits. My F-350 requires some high pressure's in the tires 65 front and 80 back. Can anyone recommend a good 12 volt high volume compressor that would be up to the task of filling them if needed.
Any help is appreciated.
08-27-2015, 07:34 AM
Harbor freight has a 150psi pancake type. I have the 100psi. Works fine. There are smaller ones available at higher prices if you search "portable compressors.". Good luck.
2018 Forester 3011 DS
08-27-2015, 07:49 AM
Thanks for the reply, I actually have the Harbor Freight sales paper in front of me now. Lots of reviews and opinions but I was looking for folks who actually are pumping 80 pounds of air into a tire and not 32 -35 pounds and getting their opinions and suggestions. And price of course will be a consideration.
Thanks again.
dcheatwood forgot to ask, how long does it take to pump that kind of air into your tire.
08-27-2015, 01:01 PM
Its hard with the 100 psi compressor. Takes multiple runs at it. A 150 must be better. I'd like a bigger one to get my Es up to 78psi.
08-27-2015, 01:17 PM
GLCM Warrior
We use one of these: VIAIR Corporation - 400P Compressor (P/N 40043)
It pumps my RV load rated E tires up to 80 psi without any problems. I've used it once on the F350 tires (same psi as yours) with no problems too.
It might be a little pricey...but it works very well, is compact, quiet and very easy to use!
Only thing I wish it had was a longer set of cables for hooking it to the battery. I figure I can extend its reach though using my jumper cables if need be. I also got a second air hose (25 ft extension) so that I can reach the RV tires without unhooking if needed...but it can also be hooked to the RV battery as another method to extend the reach.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
08-27-2015, 01:22 PM
I do not have one with a tank where I can also set to under 40psi to blow out my lines. Are any of these capable of pumping up a tire and also blow out lines?
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
08-28-2015, 05:27 AM
Lefty59: Now that's what I'm talking about. And a bit pricey like you said but if it works and you have one emergency where you need it then it's worth the price. I have AAA and blew a camper tire once. With my bottle jack and 18v impact wrench in hand, I changed the blow out in about 10 minutes way before AAA could have come out and do the same job. I don't like to wait for someone if I can do it myself.
Thanks for the link and info.
Just need to find the cheapest place to buy one now.
08-28-2015, 01:50 PM
Highly recommend. I just got this one and tried it out for the first time this week. Easy to use and works fast. This one comes with the extension hose and I can easily reach all of the tires on my TV and TT. Looks like it's about $50 less than I paid just a couple of weeks ago too!
http://www.amazon.com/Viair-40047-Au.../dp/B004B68XGC
08-28-2015, 01:55 PM
Pricey
Wow! Amazon had them for $161. Wonder what the difference is between this brand and the many others that look the same but cost much less? Harbor Freight shows about $69 right now but I wonder if will top off an RV tire up to 80 psi.
It's getting difficult to find 80 psi air on the road and I've been looking at the 12V compressors but find it difficult to believe they can top off an RV tire in a reasonable amount of time.
Nick, Sharon and Finnigan
08-28-2015, 02:05 PM
I believe the differences are that the 40047P-RV has the automatic shut-off and the RV model includes more accessories to fit all variety of RV tire types per the
manufacturer's description.
08-28-2015, 02:06 PM
I have a Superflow MV 50. Got it from Amazon.ca Just looked at Amazon.com and it's there also. I also carry a 110 volt compressor in the 5er.
08-28-2015, 02:43 PM
air compressor
I have one it works great.
08-28-2015, 03:28 PM
I have a Black and Decker AS1500 cordless compressor and inflator, $60 with free shipping from amazon. It says on the box that it's good for 120psi. The most I us it for is 50psi for my bicycle tires. You can dial in the desired psi, and it will stop automatically at that pressure.
08-28-2015, 04:58 PM
12v = frustration
I finally gave up on the 12v air compressors. I bought a pancake at Harbor Freight. I always carry my generator anyway... no more frustrations!
2016 Vibe 268RKS
2015 Chev 2500HD
08-28-2015, 07:29 PM
Has anyone used the Jumpstart which has a built in compressor that runs up to 150 psi? I notice both Costco and Sam's carries the unit for $60. Unit had a fairly heavy weighty battery in it. Guessing a lawn tractor or motorcycle battery.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
08-28-2015, 08:08 PM
Who Dares, Wins
Yeah, plan on sitting a long time to wait for them to get to pressure...
We have a blue hawk 2 gallon 120v one. I also have given up on the 12v ones. I generally carry a geni with me or will have 120 when I get to the campground.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
08-28-2015, 08:40 PM
Compressor
Harbor freight 150 psi 12v with 2 year warranty 69.00 will reach anywhere on RV or truck battery clamps quick and powerful compact with bag and all asseccories size of a football maybe little bigger
08-28-2015, 10:21 PM
I bought the Viair 450P. Yes, it's a bit pricy at over $200, but it's built like a tank, all metal, stainless on the outside, sits on a diamond pattern vibration pad, comes with a 35' hose and a 12' DC power cord, large pressure gage, squeeze-trigger nozzle, all in a rugged canvas zippered bag. Pressures up to 150 psi. If you are serious, this blows away the competition...no pun intended.
2018 Berkshire 38A
08-28-2015, 11:23 PM
I went an opposite direction. Sometime I travel with genny, sometimes not. Ran a 1000w inverter under the backseat of the crew cab and ran 4 ga to it. Bought 120v craftsman for about 80$ 6 amps 1.75 cfm. Doesn't take too long to pump up my d rated tires from 40 to 60 at all. Maybe 90 seconds each. To get to rv tired I just pull out extension cord out of trailer. I am about to purchase 1/2 electric impact from harbor freight and leave my cordless impact at home so I don't have to worry if I have a charged battery or not. Inverter powers my metro vac (4hp) well also.
I didn't look extremely long for a 12v because of low air volume. Did pick up a economically challanged unit for when it comes time to blow water out of lines.
Just glad to get away
