Old 04-14-2012, 06:46 AM   #1
Brigitte
boubou's Avatar
1200 lbs Trunnion bars interchange with 800 lbs
Question:
Can the 800 lbs trunnion bars be changed to 1200 lbs without changing anything else?
Are hanger brackets, hitch head, cam arms and mounting plate remain the same?
in other words, can I just purchase 2 trunnion bars of 1200 lbs and use them on existing equipment (might be over tongue weight for 800 lbs)
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 04-14-2012, 08:31 AM   #2
I had a Reese WDH and switched trunion bars only from 600 to 1000 without changing anything else. I just changed the bars themselves, didn't change the trunions either. The older style bars had a removable trunion on the bars themselves. Just pulled a bolt, changed the bar & chains over and had new 1000# bars.
Old 04-14-2012, 09:08 AM   #3
Brigitte
boubou's Avatar
I am wondering about the sway control cam themselves where the bars rest. ( remember , i got the cam bracket welded on frame).
Superglide 2700
Timbrens
Old 04-14-2012, 09:59 AM   #4
Short answer, yes. All the bars from a manufacturer are the same length. That is why there is one set of directions for installing and setting up. a hitch. If each wight bar was different, it would have to have a different set of installation instructions.
If you go to the heavier bars, you may have to change the ball angle to get the correct amount weight transfer.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-14-2012, 10:20 AM   #5
Brigitte
boubou's Avatar
How about the width of the bar
Which sits in the cam part, same?
The reason I ask is that when i mentioned/question the store I purchased the system from, the owner/salesman/installer assured me 800 lbs was more than enough. I also asked what was involved
In changing bars, he showed me the increased size of bars (1200) and said i needed to
Change the cams where bars sit. Not sure if he was just snowing me so not to have to exchange bars or not
Superglide 2700
Timbrens
Old 04-14-2012, 10:38 AM   #6
Brigitte
boubou's Avatar
Will 1200 lbs bar fit into this cam currently used with the 800 lbs bar
Superglide 2700
Timbrens
Old 04-14-2012, 11:01 AM   #7
Reese dual cam hitch. Reese only sells one size cam, so they all will work with the those cams.
Here is the link to Reese website, you can verify yourself.
http://www.reese-hitches.com/
A lot of sales people don't have a clue sometimes, they just want to sell.
LadyWindrider
Old 04-14-2012, 11:12 AM   #8
Brigitte
boubou's Avatar
Thanks for all your replies, puts my mind at ease.
I was nervous about having to change the brackets (if tw over 800) now that I got them
Tac welded
Thanks again
Superglide 2700
Timbrens
