06-05-2011, 10:11 PM
14" to 15" tires
Hello;
Just buying a Surveyor and it is coming with 14" tires, the trailer seems a
little low, any issues if I change to 15" tires?
It is the surveyor 295 sport...I noticed other surveyors come with 15"
thanks!
Db
06-05-2011, 10:15 PM
not sure on your model but some have spacers to give that little extra to stuff the larger tires
if you can meausre the center hub to fender lip on one that has the 15" wheels and then measure the one you are buying to make sure there is enough room for the larger tires
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
06-05-2011, 10:27 PM
Thanks!
Will do it's still on the lot waiting pick up...it came with "optional" 14" aluminum
rims I would rather have the plain steel white ones with 15", I think the dealer will
swap them for me as no cost to them.
Db
06-08-2011, 10:54 AM
Moderator
15" are unlikely to fit. Our 235 has only 2" between the tires so larger diameter will not fit. There is a spacer kit but I'd wait to see whether it is needed.
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
06-08-2011, 11:10 AM
Perhaps but the standard tires are 15inch the optional ones are 14in w alum rims.
06-09-2011, 07:14 PM
Moderator
Well, even if 15" tires are available, you would probably get at most an increase of 2" in diameter and you would only get half of that increase (radius). So, if clearance is your concern, you are better off with the riser kit. I believe the riser kit gives you 3". You would need a tire diameter increase of 6" to equal that; an improbable scenario I think.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 563 |
| 115 members and 448 guests |
| 4Jeeperz, acadianbob, autorot8, Bearcat55, Big Dawg, blaisrv, BlakeB, bob34787, bob7794, boubou, bryndlwulf, buzzmonster, cabane, campers5delite, camper_Lucy, caper, Capsfloyd, cat1956, CCrane2299, Char_n_Kath, chevy02, chof16, comfun1, condo, Cowracer, cstover, cyclepuck, danred, DAREK.NIEUWSMA, dec1952, Deputyseven, dewcew72, dimurrrw, dnaraG_1M, dnicekid, Douglasdh62, dtolar, duchie, dunnnc, elind, flc, fordmantpw, franepn, FreedomTracker, GeorgieGirl, gmurrell, Gquist, gsocamper, HAARubicon, Hammertat, Happy Vibe, herk7769, Hob, hokiecampers, icebrew, isz, Itsthetwoofus, JamesR, JENSENRVDirect, JJones, jkinger, jmswms, JoeR, joess, jphillips1075, judy3972, karznromz, lbhird, LFugate, life2short4nofun, LiteEmUp, LKicklight, lmcleister, loki, Love2run, Mr. Legato, mtl roofer, mtnguy, munty, mx800, nailit, NancyTX, Pharmofish, phuss, Pinesman, PrairieBoy, prof_fate, punkaccountant, pwrplay, rawlus, Rescue1, rickthelen, rjshiflet, rschoono289, rstewart06, russpat, Sailfish Bret, sbond, scout800, SDENN4281, Skippkon, softwarejoe, Stagger, Stank Bait, steeleshark2, Stinger, Tech Admin, thaithco, travel3246, Triguy, vinman72, willy, windrider, wmpmurray, wneise |
| Most users ever online was 996, Yesterday at 11:04 AM. |
