Old 07-14-2013, 06:43 PM   #1
JackRAbbit's Avatar
16K Reese hitch issue
When I unhitched my 5th Wheel after this weekend the handle to release the hitch got stuck open. It only took a little tap on the clamp to release it. I have always had some minor issues with it on both hooking up and unhooking. Has anybody experienced this? And is this something that I should be concerned about?
JackRAbbit is offline   Reply With Quote
Old 07-14-2013, 06:47 PM   #2
Have you lubed all the pivot points?
Old 07-14-2013, 07:40 PM   #3
JackRAbbit's Avatar
No I haven't greased the pivot points. I never thought of it. Do you think that could cause the clamps "stick"?
Old 07-14-2013, 07:48 PM   #4
Definitely, I took my hitch plate off and turned it upside down and lubed every pivot on it plus the big pivot pin on the hitch frame. Sprayed a little lithium grease on the jaws and on the sides of the chute even though the pin doesn't rotate in the clamp.
Old 07-14-2013, 07:57 PM   #5
B and B's Avatar
Hello, I had the clamp stick upon unhooking the first time. The dealer did not lube anything up at all. It just was about half an hour ago.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-14-2013, 08:13 PM   #6
PPST OGCDG
Frank-VA's Avatar
I do the same thing that OC does. I have a slider so I Lube the rollers on the slide and the latching mechanism for the slide.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
