Old 07-21-2015, 11:53 AM   #1
Pauls Toy Hauler's Avatar
18K SuperGlide owners...question? Fix? or As Is?
As a preface I know this setup has areas of excessive slack and there are those that will not purchase it because of that. I am not one of them. I purchased it and really like the automatic feature and the slack doesn't bother me however.........on to discussion below
My trailer is a toy hauler that when loaded at a minimum has an 800lb+ Harley in the back and at most an additional 500lb sportster. So this makes my tongue lighter obviously. I don't skimp on loading the front down but I don't think I have 800lbs of stuff to load up front. Anyways I digress.
When towing going 55+ mph and I come to some bumpy highway road and I mean more wavy the trailer tongue bounces up and down and I know it's probably the weight in the back making the front even lighter, but with the superglide hitch there is some play in the slider.
If you look at the picture below the play is from the hitch plate when sitting on the hitch. It then is held down with two pins. I thought I read of a fix but maybe I'm imagining it. But my thought was drilling out that pin to a larger hole and using a larger pin to eliminate the play. Anyone heard of something like that?
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
superglide
