Old 04-14-2015, 11:05 AM   #1
mlangdn's Avatar
2.5" to 2" Reducer
I bought a 2.5" to 2" reducer today from Tractor Supply. It is a Reese brand, and it slid right in. It is not a tight fit and it does have just a bit of wobble. Other than the possible noise factor on bumps and stuff, will this be a problem with just a bit of woblle? It has about a 1/16th or so bit of play.
Oh yea, weight is not a factor since my current TT only comes in at about 7500 loaded
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 04-14-2015, 11:17 AM   #2
Witch Doctor's Avatar
I doubt if you will even know it when towing. 1/16" is nothing. If it becomes a problem slip a 1/16" wedge in between....Was it a Reese that you put it in? I would just go on my way and don't worry about it. I have more slop then that on my 5th wheel pin.
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-14-2015, 11:24 AM   #3
mcnabbwr's Avatar
There should be some play, if it was a tight fit I doubt you would be able too remove it after a short period of time.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 04-14-2015, 11:28 AM   #4
You can drill and tap the collar to 3/8-16 UNC on the side and bottom and install a 3/8" gr 8 bolt with a tapered end and tighten it(them) to remove the slack. Also serves as a theft deterrent.
Name:	Hitch tightener.jpg
Old 04-14-2015, 12:55 PM   #5
mlangdn's Avatar
Thanks guys - I just found out I'm gonna need a longer pin as well. At least 5 " long.
The Reese reducer is going in to a Pro Series WDH. The reducer has a bit of play, and I just put the WDH in and see that together there is about 1/4" of total play. The pin isn't long enough going through the 2.5" receiver to put the holding pin through the hole. I also need a bigger socket in case I have to move the ball. Back to the store...
Old 04-14-2015, 01:23 PM   #6
thebrakeman's Avatar
Just be sure the reducer is rated for at least 7500 lbs. It's certainly not rated as high as your 2.5" receiver.
thebrakeman is offline   Reply With Quote
Old 04-14-2015, 01:53 PM   #7
mlangdn's Avatar
The reducer is a sleeve that fits totally inside the 2.5" receiver. Its not an adapter that goes smaller. If I remember correctly, using the sleeve takes me from 14,000 down to 12,000 - the TT is well below that.
Old 04-15-2015, 08:30 AM   #8
OK. I didn't understand what you meant by weight not being a factor. It's entirely possible that a 2.5" sleeve could be made by some low-grade steel/design, and only have a 5000 lb rating.
Seems yours is rated for 12,000 lbs. Great!
Old 04-15-2015, 08:49 AM   #9
Crockett's Avatar
c.r. brophy makes a shank that is 2.5" and reduces to 2" for the WD head if it gets to be a nuisance.
Crockett is offline   Reply With Quote
Old 04-15-2015, 12:45 PM   #10
I purchased a product called hitch-vise. I have a 5th wheel but I also tow a dump trailer and 20 ft. boat. There is no noise and it keeps the hitch pin hole from turning oval.
Hitch Rider Racks: Bike racks, trike carriers and no wobble tow carry racks
offduty11 is offline   Reply With Quote
