Old 08-24-2016, 04:08 PM   #21
CWSWine's Avatar
Originally Posted by Ian Walker View Post
Dear Seachaser186,
OK on my truck door reads: GVWR 3220kg / 7084 lbs
FR/AVT 1810kg / 3982lbs w P275/65R18
RR/ARR 1880kg / 4136lbs " " "
I have LT275/65R18 tires
Truck built May 09 in San Antonio, TX
Now in the 2010 Owners Manual pages 266 & 652
model code: USK55L-TRTDKA
Standard Bed (6.5 feet)
4wheel drive
Double Cab
5.7L V8
3UR-FE engine with towing package
GCWR 15,500lbs
Tow Capacity: 10,100 lbs
Trailer 37foot: GVWR 8600lbs
Cheers
What you need to do is pull onto a scale ready to camp and the front and rear axle of the truck should be less than 7084 lbs. I would guess you over that but you won't know till you weight it and if it was me If I was over weight I would at least want to know by how much. In the states it cost 10 bucks at most major truck stops. You will run out payload long before you run out tow capacity towing a 5er.
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
Sold - 2014 Cougar SGS
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is online now   Reply With Quote
Old 08-24-2016, 04:44 PM   #22
Thanks Seachaser186 !
Unfortunately I'm about 3000 miles from the trailer right now.
When I get to it I only have to haul it on flat ground about half a
mile from storage into a CG. However it was hauled from San Antonio
to the Rio Grande Valley. Then to Phoenix & back to Rio Grande
Valley then back to Phoenix. No troubles and it handled well but
then I'm no expert. Like everyone else I'm learning as I go.
Appreciate your input.
The other TT I have up north has a GVWR of 4800lbs so much
lighter to pull. That I've pulled all over the US including the mountains
of Colorado & not a spec of trouble.
Ian Walker is offline   Reply With Quote
Old 08-24-2016, 09:08 PM   #23
Hey Ian, that wasn't me that responded it was CWSWine; but still accurate info that you will run out of payload before towing capacity. What I was questioning was your previous post where you dissed the F150 EB in favor of the Tundra because it could tow 11300 instead of 7600. Of course the Tundra can't tow that but I see you corrected that to 10,100. Looks to me by your numbers you will have to pack light in both your TV and TT not to exceed your GCWR.
Seachaser186 is offline   Reply With Quote
ecoboost
