07-08-2013, 07:53 PM
2 days of reading and more confused...enough truck?
Hello all.
First, let me apologize for yet another "do I have enough towing capabilities for the TT I'm considering buying" question. But, like many here, after reading this forum, my owner's manual and plenty of other google researches...I'm now more confused than ever.
I have a 2009 Suburban 5.3L with all the manufactured installed tow package upgrades. So this is supposed to provide towing capbilities of 8,200 and a GCWR of 14,000. That's the easy part to understand. Then comes the other dozen or so acronyms I'm supposed to know.
There is me, the wife and 3 young kids (8, 5 and 8 months) plus some gear, obviously. We're considering moving from a pop-up to a TT, and the unloaded weights seem to come in from 6,000 to 6,700 lbs (specifically, a Palomino SolAire 292, 307 or 317).
Every sales guy says I'll be fine, then I come here and it seems the pop-up I've been towing very easily for 10 years is a highway death machine.
Any thoughts? Thank you, guys.
07-08-2013, 08:15 PM
You need the maximum the truck can weigh (GVWR), which is located on your door jamb. Then you need the weight if the truck with you, the wife, kids, everything for camping (GVW). Subtract what the truck weighs from the maximum it can weigh, that is the available payload.
That is how much you have for the hitch weight.
07-08-2013, 08:20 PM
For example my info.
2010 Tundra Double Cab 5.7 4x4
2010 Graywolf 28BH
Truck GVWR 7200
Truck Weight 5620
Payload 1580
Wife 150
Dog 160
Kid 50
Left over 1220
Hitch Weight 950
270 lbs left for odds and ends.
Hope this helps.
07-08-2013, 08:22 PM
If you tag a 6000+ lb camper to the back of your burb, plus all of the gear for 5 of you, it just seems like a lot to be asking of a 5.3
07-08-2013, 08:47 PM
thanks.
Per the sticker on the door jam, the GVWR is 7,400.
The spec sheet shows curb weight of 5,600. If I assumed 1,000 of cargo, that's 6,600 or a difference of 800 lbs for hitch weight. (is that the same as tongue weight?)
If I'm close to accurate so far, and having read that hitch/tongue weight should be 10-15%...than that would allow a total trailer weight of 5,333 - 8,000 lbs?
I doubt I'm doing this right.
07-08-2013, 08:53 PM
Yes. That looks about right. I am close and I know it. The have probably bern times I have been over my gvwr by a few pounds. I am in process of finding a new truck, but the wife also wants a 5th wheel next.
As for the other terms GCWR is the maximum your truck and trailer can weigh together. You also have RAWR which is the maximum weight your rear axle should carry. I hope I am helping.
07-08-2013, 09:00 PM
Always Learning
Originally Posted by Kbosch74
thanks.
You're on the right path! So, yes - "hitch weight" is the same as "tongue weight" for travel trailers and "pin weight" for fifth wheels. Essentially, this is the amount of the camper that pushes down on the rear of the vehicle and adds to the truck's weight (so as to not exceed the GVWR).
You're also spot-on about the 5,333-8,000 pound TT. Bear in mind that this is the *loaded* weight of the camper not the mythical dry weight. The typically user adds 1,000-1,500 pounds to the advertised "dry weight". I prefer to calculate off of GVWR just to plan for a worst-case scenario. But, I'm generally overly safety conscience.
You have it all, but I'm going to offer up a link to my page on this topic:
Learn To RV: What Can I Tow?
07-08-2013, 09:38 PM
Thanks, Ependydad.
I just read your page as well. That, and the above replies, are the most simple understanding I've read yet.
Even going through this exercise, it seems that really we're just getting a ballpark idea, correct? I mean, unless you weighed your vehicle and TT every time, all of these factors are going to vary from trip to trip. And the 10 - 15% figure allows for a HUGE difference in TT weights.
All that said, I'm considering a TT with a dry weight of 6,000 - 6,500 lbs. If I had 500 lbs of cargo in the TT (which seems like an aweful lot), it appears that I'm pushing the out limits but not surpasssing them. I figure between that fact, and just some common sense driving (safe speeds, safe distances) I should be OK.
Am I missing anything?
Thank you for your advice and time.
07-08-2013, 09:51 PM
Always Learning
Thanks for the kind words. And yes, it's generally a ballpark unless you use the GVWR of the TT and 15% for a "worst case scenario". That gives you the most flexibility. But, like I said - I'm generally overly safety conscience.
I do strongly recommend a weighing or two to get a feel for where you're at. And, since you already have the tow vehicle, load it up like you were going camping and go get it weighed. I was pretty surprised to find out that we used up 1,200 pounds of our payload with our usual "ready to travel" setup - never mind "hitch weight". Find out what your *actual* available payload is (GVWR minus wet truck weight).
500 pounds of cargo seems like a lot, but the dry weight is so absurd. My camper is a lot heavier, so the numbers are likely skewed a bit. But- my advertised dry weight is 400 pounds less than my yellow stickered weight (the weight as it left the factory) and that's before it made it to the dealer's lot and they installed things as part of my original purchase (slide toppers and stabilizers). So, the day I drove it off of the dealer's lot and before I put one thing in, it already weighed more than the yellow sticker. Then you add your stuff. Then you add some water in the tanks (10 gallons is 80 pounds) and some in the water heater (6 or 10 gallons - 48-80 pounds). And then you fill both propane tanks. And then the bed's really uncomfortable and you put a mattress topper on. And pots and pans. And clothes. And stupid knick-knacks. And... and... and... and...
It all adds up. Again, I'm on a bigger scale than you- but I've added about 2,000-2,500 pounds of stuff (haven't weighed in a while and I carry a fair amount of water) from my advertised dry weight.
As for knowingly exceeding limits or not - lots of people do it and arrive safely. I prefer those that do, do it knowingly. Get weighed and make an educated decision.
07-08-2013, 10:01 PM
Good stuff. Thank you.
07-08-2013, 10:04 PM
The first thing you need to do is better understand your trucks capabilities than just my truck can tow x lbs. (I learned this the hard way). Most TV are limited by their payload and not their towing capacity. To find out your TVs true towing capacities then you need to go weigh it. Load the tv up with all occupants, pets, and cargo that will be in it when towing plus a full tank of fuel and then go weigh it at a local scale ( CAT Scale ). Weigh each axle on a separate scale pad so it will give you a breakdown of front and rear axle weights individually and a total weight. Take the scaled Truck weight and subtract it from your Truck gcwr (gross combined weight rating) to get your adjusted towng capacity (the loaded weight of trailer needs to be less than this). Take the scaled weight and subtract it from your Trucks gvwr (gross vehicle weight rating) to get your available payload. The loaded tongue weight needs to be subtracted from the available payload. You also need to know your RAWR (rear axle weight rating) and the actual weight of the rear axle (same for the front axle, FAWR). The tongue weight will add weight to your rear axle (although a wdh will transfer some weight to front axle and some weight back to trailer, the majority of the tongue weight will still hit the rear axle). You need to be within all of these ratings.
Next understand you will never tow an unloaded or dry trailer. Those numbers are somewhat irrelevant. You can either add the amount of weight of cargo you will tow to the dry weight (this is heavier than you think as most add 1000-2000 lb of gear) or simply use the tt gvwr to do your calculations. Being that this is your first tt, using the tt gvwr is the safer route for you. Next understand that the tt loaded tongue weight needs to be subtracted from your available payload. The loaded tongue weight is typically 13-15% of the loaded tt weight. For your purposes go with 13-15% of the tt gvwr. Hopefully this helps clarify some things for you.
ps if you can't get to a scale look at the tire loading sticker in your door for "all cargo and occupants not to exceed x lbs". subtract the weight of family and gear from that and you have a rough payload. you can work backwards. if you have 800 lbs available payload then you are looking at no more than 5300 lbs loaded weight (800 lb payload/.15 for tongue weight percent=5300).
2014 Sabre 34REQS-6
07-08-2013, 10:21 PM
I went from a hybrid TT to a 36' TT with a dry weight of 7200. Based on all of the specs I was at my limit for my Yukon XL with tow pkg. I had plenty of engine but did not take into account the "push" from big rigs on the interstate. My first trip was 30m from home but I had my family drive seperate as I was not comfortable. Purchased a good used 2500 and no worries. The rigidity of the frame is so much more superior on a 3/4 vs 1/2 ton. I have since graduated to a fiver and kept the truck. If I knew then what I know now I would have skipped the TT and gone direct to the fiver once I got the correct TV...Good luck and you are doing the right thing by asking for advice.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
