Old 06-26-2015, 10:09 AM   #31
Originally Posted by rdenslow View Post
Loved the 7.3... loathed the 6.0. Mileage was terrible 13 day in day out and 7 pulling my 29th 5er. The egr system and passenger side fuel rail went at 28k and the service manager at the local Ford garage told me to get rid of it before the warranty run out...also spent time in the shop for electronic issues in the dash and a new odometer. .. Never been a Dodge lover at all but a huge fan of Cummins. .. better milage, more torque, no headaches.
MY 05 got 19 Average and 14 towing 15000lbs. I now have a 2001 7.3 that is great condition.
harderd is offline   Reply With Quote
Old 06-26-2015, 10:10 AM   #32
I only gor rid of it b/c I needed a longer bed.
Old 06-26-2015, 03:47 PM   #33
Rodgers's Avatar
Wow glow plugs, I used to to put those in Caterpillar motors back in the early 80s. Old motors or way behind in technology.
Rodgers is offline   Reply With Quote
Old 06-26-2015, 05:15 PM   #34
mike.t's Avatar
Gasser's still use spark plugs.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 06-26-2015, 05:53 PM   #35
deebarjay's Avatar
...........not so. try wikiup and learn diesel fuel combustion/low flash point.........glowplugs are only needed for starting in cold temps. even 2015 motors down have them....it's what makes them start......have another beer.
deebarjay is offline   Reply With Quote
Old 06-26-2015, 05:57 PM   #36
mike.t's Avatar
Give him hell deebar. Then tell him about hot compressed air.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 06-26-2015, 08:40 PM   #37
MagnoliaTom's Avatar
I used to put unleaded gas in my cars in the 80s.
2014 Freedom Express 320BHDS Liberty Edition 50th Anniversary
2005 F250 Lariat SuperCrew 6.0 PS Diesel
2004 Excursion Limited 4x4 6.0 PS Diesel
2000 Excursion Limited 7.3 PS Diesel Sold:crying
MagnoliaTom is online now   Reply With Quote
Old 06-26-2015, 08:58 PM   #38
mike.t's Avatar
Bout all they had in the 80's cept for diesel.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 06-26-2015, 08:59 PM   #39
Tonkatoy77's Avatar
What Cat engines took glow plugs? I work on on-road engines and have never seen glow plugs in a Cat. And for the record, my 07' Duramax has them.
The Cummins engines do not have glow plugs. All they have is an intake heater, which is more for emissions than anything.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 06-26-2015, 11:16 PM   #40
deebarjay's Avatar
aint google wunnerful !!
Diesel Engines That Are Equipped
With An Air Inlet Heater
If your engine is equipped with an air inlet heater
(AIH) for cold weather starting, only use an approved
continuous
flow ether system that is installed
by Caterpillar or by a Caterpillar dealer. The
engine software must be activated in order to insure
that ether injection and AIH operation will not
occure at the same time. Use of any other manually
or automatically operated ether started aid system
could cause an explosion resulting in injury
SOP with bigger Cat equipment for years Steve. Older D6/7/8/9 dozers, 621, 631, 641, 651 scrapers, 825 compactors, nearly all the bigger glow plug engines from Cat require ether, and plenty of it during temperatures below about 35 degrees above. The new direct injection Cat's do too. Detroit's, Cummins, Mack's, Allis Chalmers, International, and many other engines with or without glow plugs all needed help from ether. The main problem with the older pre-cup machines was, however, poorly designed and maintained glow plug and related electrical systems. It was hard to ever find one that was 100%. I'd have to write a separate chapter about all the trouble Cat has had with glow plugs and electrical over the years.
power
