Old 04-23-2014, 01:15 PM   #11
Chunkychuck's Avatar
The four points of contact would remain. Instead of having those tees that rotate to grab onto the puck, you would have four pucks that are threaded for a one inch bolt. You could notch out the upper portion of the adapter rail directly over the bolts to allow socket use and use flat washers and a lock washer to add additional pulling surface for the bolt to pull the lower rail tight to the bed, just like the jam nut does on the current adapter. But I'm not a structural engineer so there is probably something wrong with it.
2013 Brookstone 340LS Ruby
2014 Dodge 3500 Diesel
Chunkychuck is offline   Reply With Quote
Old 07-02-2014, 01:38 AM   #12
Originally Posted by MeepMeep View Post
Glad you were able to get in. I haven't found any reason to take it back out yet, but I'm guessing there'd be a crow bar involved��
Ok, so I hope this does not sound stupid, but I can't seem to remove the plastic covers that came over the hitch holes in the truck bed. I just got the 2014 Ram 3500 and ordered the mopar plate and hitch.
When I try to twist the pucks using the handle, it goes so far inside the outer ring than stops. Any further turning/twisting and the outer plastic ring just keeps turning. I have tried pulling up but I cant seem to get it to release up and out.
What did you all do to get yours out so you could install the rail adapter plate? BTW: I have not tried to pry up on the plastic covers as I assume they are reusable when you remove the plate when not towing. I do not want to damage them or the truck bed metal underneath.
Any help would be great, very little info on these Tow Prep packages are available.
mmcbride56 is offline   Reply With Quote
Old 07-02-2014, 02:10 AM   #13
The covers were off mine so I can't help. Sorry
Old 09-14-2014, 08:02 PM   #14
Fire Instructor's Avatar
I'm stuck where you were stuck! I don't want to damage anything, but just HOW did you get the plastic inserts out???
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 09-14-2014, 08:39 PM   #15
97Powerstroke's Avatar
I got a 2014 2500 with the pucks.
Hold the outside "ring" with one hand, twist the inside circle with the other. They don't pop out. I used my pocket knife to gently pry it up.
97Powerstroke is offline   Reply With Quote
Old 09-14-2014, 09:03 PM   #16
Thank you! I'll give it a try in the daylight!
Fire Instructor
Old 09-15-2014, 06:28 AM   #17
Mddle of the Rd Extremist
MeepMeep's Avatar
I used a flat blade screwdriver - also with positive results...
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
2014, 3500, 500, bed, dodge
