Old 10-02-2015, 11:15 AM   #101
Tonkatoy77's Avatar
Originally Posted by Kenny kustom View Post
It's dot law.
If I am directed into a weigh station, and am over my gvwr. It's a ticket.
I also cannot leave until I am under.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Can you find and post up the "DOT law" for me? I just have NEVER seen a "law" stating that it is illegal to exceed your GVWR. And there are two different scenarios going on here. If you get in a wreck and kill someone, sure, I can see them throwing the book at you for negligence. But would that driver get an overweight ticket? Would the fine vary from the amount overweight? How much is overweight? Most DOT scales aren't exactly accurate. They are weighing trucks in the thousands of pounds over, not hundreds.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 10-02-2015, 02:04 PM   #102
jlgail4309's Avatar
I think the Diesel Vs Gas debat will always be up for debat. The eco boost is a beast for a 1/2 ton truck. If they are towing a 5ER with that rig is must be a hell of a towing rig. But it is MAXED out towing rig. Then you drive at high speeds maxed out that's when thing happens in a hurry. I think the daily driver is the reason you see so many 1/2 tons towing these large trailers. It's a choice between better towing safty or a better daily driver. I'm not sure the new trucks the daily driver is that much differt. I do think the are all are over priced. It's a choice !!
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 10-02-2015, 03:44 PM   #103
http://www.dot.state.pa.us/Public/DV...rms/MV-70S.pdf
All I can find is weight class- most fines are local police pulling over 1/2 ton to 1 ton to generate $$$.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 10-02-2015, 06:36 PM   #104
Tonkatoy77's Avatar
Am I missing something? The link sent me to a form showing what it costs to register your pickup. Still no law. I guess I'll keep waiting......
Old 10-02-2015, 06:44 PM   #105
CWSWine's Avatar
Part III number 8 at the bottom of the page under FAQ.
8. Overloaded Recreational Vehicle (RV).
The FMVSS have requirements for the manufacturer to use proper tires and rims for the gross axle weight rating (GAWR) and the gross vehicle weight rating (GVWR). The manufacturer may determine the GVWR by adding cargo capacity (if any) to the curb weight of the vehicle as manufactured. The wise consumer, before purchase, will determine if the vehicle has sufficient cargo capacity to carry the weight of water, additional equipment (such as televisions, and microwave ovens), and luggage. The manufacturer’s certification label must show the GVWR. The GVWR must not be exceeded by overloading the vehicle. There is little the government can do to assist a consumer who has purchased a vehicle that has insufficient cargo capacity for its intended use.
Importation and Certification FAQ's Directory--Trailers and Heavy Trucks
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 10-02-2015, 06:58 PM   #106
Tonkatoy77's Avatar
2015 F150 Platinum Ecoboost- great tow vehicle!
Once again, that is a requirement that is set in place for the manufacturer. I do not see where it states that it is against the law for me to overload my vehicle.
Old 10-02-2015, 07:04 PM   #107
CWSWine's Avatar
What is the consumer if not you? This is the FAQ section not the complete law.
You want to read the entire reg be my guest since page on up pages on the subject. I ended up at the library to read it.
Old 10-02-2015, 07:12 PM   #108
Nope, I cannot find anything but 26,0001 or higher
2006 Honda Goldwing
Old 10-02-2015, 07:22 PM   #109
B and B's Avatar
Nice post! Good to know the government can not help someone that puts together a unsafe combination.
no such rules in Canada I have ever found other than max 23,500 combined TV and 5th wheel weight. You can get a Dodge that tows 31,000 lbs, but you can not tow anything without a CDL and commercial plates and annual inspections.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 10-02-2015, 07:27 PM   #110
Tonkatoy77's Avatar
Oh, I'm sorry, i didn't (and still don't) see where it states that it is against the law for the consumer to exceed GVWR. It just said that must not be exceeded. Or what? If I exceed it, what happens? All violations have a code used. Something like a CFR or ORS #. What is the actual law? What is the penalty? If there is a law, there has to be something out there stating the exact law. Not some sentence at the end of a paragraph.
ecoboost, f150, tow vehicle
