Old 06-13-2016, 08:28 AM   #31
Originally Posted by KenHwy61 View Post
That is true. The 3/4 ton class could be eliminated because in reality they are built to 1 ton standards and then derated to create the 3/4s. The difference between the two is often only a leaf spring.
Today's Super Duties, there isn't even a leaf spring difference. You can get the camper package on the F250 which gets you the overload spring, just like the F350.
Same everything else (brakes, differentials, axles, etc.). The F359 has the taller blocks though.
The F250 is handicapped at 10,000 GVWR to keep it a "class 2" truck. Even though it is the same as an F350.
325BH is offline   Reply With Quote
Old 06-13-2016, 12:01 PM   #32
CWSWine's Avatar
Set a 3200lbs pin weight on F250 Camper Special and then set it on a F350 then come back and tell there isn't a difference. I did just that!!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 06-13-2016, 12:58 PM   #33
CaptnJohn's Avatar
My 2016 F250 6.7 with the camper pkg just 3 leaf springs. An F350 has 4.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-13-2016, 02:11 PM   #34
I'm talking SRW here. Should have specified. Big difference between SRW and DRW.
Old 06-13-2016, 02:13 PM   #35
CaptnJohn's Avatar
Both are 2016 Single wheel... my F250 and neighbor's F350
2016 F350 diesel
Old 06-13-2016, 02:19 PM   #36
Every F350 SRW and F250 I have looked at (new ones) on dealer lots, and that is many, have the same leaf springs. The only exception is the overload spring, which comes with the camper package on the F250.
The F350 does have taller blocks, which provides a couple extra inches of travel.
This is all well documented. Just do some searching. You do have to evaluate newer ones though. They have changed over the years.
Not trying to be argumentative, just answering questions.
