Old 06-08-2013, 06:52 PM   #41
Here are the updated CAT Scale results from today:
Truck Specs:
GCWR (Gross Combination Weight Ratting) = 11,170 lbs
GVWR = 5,500 lbs
GAWR Axle Front = 2,755 lbs
GAWR Axle Rear = 3,110
Max Tire and Max Cargo = 1,050 lbs
Truck without Toy Hauler:
Front Axle (Steer) = 2,800
Rear Axle (Drive) = 2,320
Toy Hauler (Trailer) = 0
Gross Weight = 5,120
Truck with Toy Hauler (Dry from the Dealer - 1 Battery, 2 20lb Propane tanks filled, Water Tank Empty):
Front Axle (Steer) = 2,540
Rear Axle (Drive) = 3,420
Toy Hauler (Trailer) = 4,300
Gross Weight = 10,260
Truck with Toy Hauler (With Can-Am Spyder and Yamaha R1 - Water Tank Empty):
Front Axle (Steer) = 2,580
Rear Axle (Drive) = 2,840
Toy Hauler (Trailer) = 5,100
Gross Weight = 10,520
One thing looks strange to me, the difference in scale weight for the trailer and truck straight from the dealer shows a gross weight of 10,260. The gross weight of the trailer and truck with the Spyder (+699 lbs, and R1 +425 lbs) shows 10,520. That is only an added weight of 260 lbs yet the Spyder and R1 weight 1,124 lbs +/-. So where is the missing 880 lbs go? I didn’t take anything out of the trailer or truck between the weights. The truck and trailer were on the same spot on the scale between the two weights....
Strange.
Name:	Just Truck.jpg
ID:	32635   Click image for larger version
ID:	32636   Click image for larger version
Name:	With Spyder and R1.jpg
ID:	32637   Click image for larger version
ID:	32638   Click image for larger version
ID:	32640   Click image for larger version
2014 FR3 30DS
Winegard Travíler SK-1000, DISH Hopper DVR Setup, AIMS Power 4000W Pure Sine Inverter Charger, 6 x Duracell Golf Car Battery GC2, LED Interior Lights, and More...
OmegaQuest is offline   Reply With Quote
Old 06-08-2013, 08:28 PM   #42
Fulltime family RVer
I'm pretty confused on that last weigh-in, myself. I could understand some weight being unloaded from the front axle and moved elsewhere; I'd still expect to see it reflected in the gross combined weight. Very strange. Hopefully some of the bumper pull folks show up.
I think a good exercise for you, once you figure that out is to determine your actual tongue weight. Seeing the incredible difference in the rear axle weights makes me worry about it being too low. As I mentioned, I had my old Durango yanked around on the highway once- scared me pretty bad.
ependydad is online now   Reply With Quote
Old 06-09-2013, 11:53 PM   #43
Dabmeb's Avatar
No matter how it's loaded you have to have the 880 # somewhere. It can't disappear.
Something went weird at the scale, it would be worth a re-weight with and without the bikes.
You gained 800 on the trailer but lost 600 on the rear axle, did you maybe catch an edge of the scale or scale plate
Dabmeb is offline   Reply With Quote
Old 06-10-2013, 07:07 AM   #44
Nope, I looked and made sure it was all on the scale. I might go back this weekend and redo them both.
I have a feeling the middle one (from the dealer without the R1 and Spyder) is off.
Because that would mean that dry weight of the trailer would be about 5,200 lbs and the sticker (with the current options on the toy hauler) says about 4,300. Then you add the battery and 2 x 20lb tank that would bring it up to maybe 4,400 max.
So that is a differance of +740ish lbs that is being reported from the CAT Scale (2nd image, dry) that are not accounted for and should not be there.
Old 06-10-2013, 08:25 AM   #45
I would guess the scale house would like to have it brought up to them. Take your slips and explain it. There might be a manager who listens.
If you do re-weigh, make sure you do all 3 weightings (with spring bars and without them and then just truck) so you can calculate your tongue weight.
Old 06-10-2013, 06:33 PM   #46
asquared's Avatar
The dry weight and delivery weight can be significantly different. What does the yellow sticker in the door (or cabinet) show? that sticker is more accurate than the fictitional dry weight in the brochure. The yellow sticker is a weight as it leaves the factory with options.
Right off the bat I can tell you that you are way over on gvwr. You gvwr of 5500 lbs -scaled truck weight of 5120 lbs gives you 380 lbs of available payload. The tongue weight must be subtracted from the payload. your tongue weight is way higher than that.
Doing the math on the second weight sheet shows a dry weight of 5140 lbs for the trailer of which 840 lbs has been placed on the trucks payload (460 lbs over your available payload). You are over your RAWR with this one but looks as though the wdh can be adjusted to move more weight off the rear axle and onto the front axle.
Doing the math on your third ticket (loaded TH)... you appear to have a loaded trailer weight of 5400 lbs of which only 300 lbs are on the TV. This time some of the extra weight on the rear axle has been off loaded by too much weight in the rear and not enough tongue weight. Too little tongue weight will give you a sway condition.
While only a 300 lb overall trailer weight gain doesn't make sense to me, I do think you need to put more weight in the front of your trailer to achieve at least 13% tongue weight and then adjust your wdh. One thing that might account for odd numbers are if you didn't have the same amount of fuel in the tank for each weighing (ie full tank vs half tank) and number of passengers, gear etc changed. also did you make any adjustments to the wdh in between weighings?
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-10-2013, 09:14 PM   #47
Fuel in the tank was the same, I went 5 miles home, loaded and 5 miles back to the Scale.
Same people and gear on both weighs, Literally I weighted, went home, loaded the Spyder and bike and went back, nothing changed.
WDH stayed the same between the two weighs.
The 4300 dry lbs. is the yellow sticker on the unit, not the broacher. That is why I think the 2nd image weight is wrong somehow.
I think the WDH is still not set up correctly from the dealer though because after they set it up at the dealer, my rear end was about 1" lower then the front so I had to set my rear air bags to 40psi to level the truck. I thought the WDH would set the truck back to the way the truck was before it was installed (level).
I do plan on getting a tongue scale to get the weight to 13-14% one of these days.
Old 06-10-2013, 09:36 PM   #48
asquared's Avatar
Air bags are something I have zero experience with. This is a thread on setting up a wdh. Not sure how to play with air bags in that. I have dealt with load leveling suspension but that is completely different.
2014 Sabre 34REQS-6
Old 06-11-2013, 12:47 AM   #49
on a side note : 2013 Tacoma uses the J2807 standard that accounts for 300lbs of people in the truck and full fluids.
LOVE the color match between truck and trailer
I have read a handfull of WDH manuals, most say to adjust your hitch with the bags deflated and then adjust pressures afterwards.
might be worth scaling the individual axles on the trailer as well.
Although you could get more weight put on the front axle and get closer to the unloaded weight of it, helping level the truck some more, i don't think I would want to remove anymore weight from the rear axle
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
Old 06-13-2013, 01:01 PM   #50
After a lot of research and comparing the best bang for the buck for something to power my 13,500 BTU AC and still being a quiet generator and light weight for when I am not on sure power, I just ended up buying two of these units: Champion Power Equipment 73536i 2,000 Portable Inverter Generator (including the parallel power kit 73500i). The price was a little under $1,200 shipped for the two gens and 67 for the power kit. I like the looks of the units and like how they stack on top of each other.
This should be plenty for my AC and with some extra juice to spare.
