10-13-2011, 09:26 AM
Brigitte
275/60R20 for towing
I am not able to find a LT tire for the Dodge Ram 275/60R20
I see Michelin LTX M/S2 but that's not a E tire, still only takes 2365@44psi
there's also the Cooper Zeon LTZ which is rated at 2998 max load
These are still P tires (XL)
What are the problems with going down to 17" some people say do it, some don't
Does anyone have LT tires in that size? where to find them?
Shasta Revere 21FBS LE
2010 Dodge Ram SLT 1500 QC 4X4 HEMI
Sheltie, Chihuahua and a Mr. Mutt
Kingston, Ontario
Days reserved 2012 (so far) 30 Days camped 2012:
10-13-2011, 11:28 AM
What are you towing out of curiosity?
If it's the Shasta 21FBS LE trailer, how much does it weigh?
I'm thinking a load range E might be super overkill for a 3000 - 4000 lbs trailer considering a max load of tires is distributed over more than 1 tire, and with a WD hitch it's even more distrubuted than just a weight carry hitch.
I realize the Michelin are XL P metrics but I've towed a good bit with a set and they tow incredibly well. That also was with a 7000 lb (weighed @ CAT) trailer of Father in law.
For clarification: I was towing with my FiL's truck with those tires. It was a F150 2006 5.4L XLT CC Long Bed.
Speedo will be off, and rear end will change from 3.92 or whatever your truck is to a different ratio.
I also had a super hard time finding this.
10-13-2011, 11:53 AM
Brigitte
yes, it's the Shasta 21FBS LE
weight at the scales: steer axle 3320
drive axle 3460
trailer axle 5140
gross weight 11920
with WD
it added about 780 lbs on the truck so if I add 5140 and the 780 distributed to truck is : 5920 for trailer (I think I add this right ?) so round it off to 6000 lbs
ratio for this truck is 3.55 right now
Kingston, Ontario
10-13-2011, 01:56 PM
If you go to a 275/65/20 you can get E rated. They're OEM to Ford Superduty w/20" wheels. A 265/70/17 is roughly the same diameter as a 275/60/20 so the speedo and gear ratio is not changed. However, going from a 20" to 17 wheel greatly reduces your unsprung weight and makes the truck feel more alive.....so I'm told
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
10-13-2011, 03:17 PM
Moderator
What do you mean by "feel more alive"?
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
10-13-2011, 05:29 PM
I used to have a 1500 with the hemi, 20's and 3.92's and pulled a 8k TT. I too was looking to downgrade._ What I found was the 20" is almost twice as heavy as the 17" therefore taking more power to get it rolling and apparently makes a slight noticeable differance (unconfirmed). I like the looks of 20's so instead bought XL p-metric tires and changed my rear end to a 4.56. What a huge differance that made... lol!!!!!
Jason and Billie
10-13-2011, 07:49 PM
Brigitte
I'm thinking about the Michelins LTX ms/2
Cooper Zeon LTZ
General grabbers XL
Bridgestones dueler A/T
BF Goodrich Rugged Terrain T/A
The difference in price does not matter, I am looking for the best all around tire. Good for towing, general all around driving and snow.
Kingston, Ontario
10-13-2011, 08:21 PM
The coopers get rave reviews on the dodge ram forums. I used the Kumho STX, they were "XL" and rated around 2900lbs. I could only get them in 275/55/20. I had a 2wd and could get away with a shorter tire. There was a noticeable difference in towing compared to the Toyo Open Country I had previously.
Jason and Billie
10-13-2011, 09:13 PM
Enjoying Member
I put 275/65/20 E rated Wrangler all terrains on our Dodge and the only issue is that they rub when turned to full stop but it's no danger to the tire... they only barley rub the sway bar in the front at the very corner on the tread so I just don't force them to rub. No other issue and we feel much more confortable with the extra ply's. Just thought we'd letcha know they fit without any real issue.
Scott n Kimmer
Nights Camped: 2012-3 2011-16 2010-10 2009-30
2007 Dodge Ram 1500 Quad Cab 2WD w/trailer pkg 345HP 5.7 Hemi/5spd Auto/3.92 Rear
2008 Wildwood 23FLSRV - Prodigy Brake Controller - BlueOx WD Hitch
2011 Harley Electra-Glide Ultra Limited (His Bike) - 2005 V-Star 650 Classic (Her Bike)
10-14-2011, 05:55 AM
Brigitte
how's the ride compared the to hp?
Kingston, Ontario
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 565 |
| 111 members and 454 guests |
| 4Jeeperz, acadianbob, autorot8, bean, Bearcat55, Big Dawg, BlakeB, bob34787, bob7794, Borwick, boubou, bryndlwulf, buzzmonster, camper_Lucy, caper, Capsfloyd, cat1956, cdbus, Char_n_Kath, chevy02, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, DAREK.NIEUWSMA, dec1952, dewcew72, dimurrrw, dnaraG_1M, dnicekid, Douglasdh62, Drmstx62, DSN46, dtolar, duchie, dunnnc, elind, flc, fordmantpw, FreedomTracker, gbpacker, GeorgieGirl, gmurrell, Gquist, gsocamper, Hammertat, Happy Vibe, herk7769, hokiecampers, icebrew, isz, JamesR, JJones, jkinger, jmswms, JoeR, joess, jphillips1075, judy3972, kegoneill, lbhird, LFugate, lmcleister, louincal, Love2run, micalo, Mr. Legato, MT28rk, mtl roofer, munty, nailit, NancyTX, Pharmofish, phuss, Pinesman, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, prof_fate, punkaccountant, pwrplay, rawlus, Rescue1, rickthelen, rjshiflet, rschoono289, rstewart06, russpat, rwzahm, Sailfish Bret, sbond, SDENN4281, Skippkon, softwarejoe, Stagger, Stank Bait, steeleshark2, Stinger, Tech Admin, thaithco, tmmar, travel3246, Triguy, vinman72, willy, wneise |
| Most users ever online was 996, Yesterday at 11:04 AM. |
