Old 07-17-2013, 07:30 AM   #1
sledhead77's Avatar
292BHDS low tongue height
Anyone else having issues while towing with this unit? It seems the tongue is mounted rather low on the 292BHDS. I get a nasty bounce at times going over dips in the road, sometimes so bad that the spring bars will actually hit the road! Same goes for uneven spots like driveways, the spring bars will scrap of the pavement! I have the bars as tight as I can get them. The truck and trailer are perfectly level when all hooked up. Any ideas??
2015 Keystone Cougar 29ROB (wait, can I still be on here??)
TV: 2016 Ram HD 6.4 Hemi 4.10s dual exhaust
sledhead77 is offline   Reply With Quote
Old 07-17-2013, 03:02 PM   #2
daydreaming about camping
jeeplj8's Avatar
There are two types of couplers on travel trailers, those that mount ot the top of the a-frame and those that mount to the bottom. I am going to assume yours is bottom mount, though a picture would confirm this.
What type of WDH are you using? Some simply hang lower than others. Trunnion bars will sit higher than round bar.
Can you post a couple pictures of your set-up?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 07-17-2013, 03:06 PM   #3
sledhead77's Avatar
Not sure what you mean by "A-frame" but you have the frame of the camper and then the what I would assume is the "A-frame" is mounted to the bottom of the camper frame. I believe your unit in your sig pic is of the same tongue height. I am using a Husky round bar type set up.
Old 07-17-2013, 03:11 PM   #4
jeeplj8's Avatar
here is an example of a top mount coupler:
and here is a bottom mount:
The A-frame is the part of the trailer that comes to a point where the couple is mounted.
If you have a bottom mount - you do NOT want to use a round bar set-up.
Old 07-17-2013, 03:16 PM   #5
sledhead77's Avatar
It's for sure top mount. Is it me or is the tongue rather low on this unit compared to others? Maybe I just have the hitch ball too low?? Can you post a pic of yours hooked up to your truck? I would imagine your truck must sit higher then mine. Just trying to get this all figured out before next camping trip.
Old 07-17-2013, 03:22 PM   #6
jeeplj8's Avatar
The 320 sits much higher off the ground, but here are some pics of my set-up with old truck. no different with new truck.
ID:	35561   Click image for larger version
Old 07-17-2013, 03:25 PM   #7
sledhead77's Avatar
Yeah I'd say a 320 does sit quite a bit higher that a 292. At current height my safety chains basically drag on the ground. Is one suppose to adjust the chains or something? They seem really long, same with the e-brake cable.
Old 07-17-2013, 03:27 PM   #8
jeeplj8's Avatar
you can twist the chains to make them shorter. Just grab the hook end and turn it a couple times to shorten the chain. the breakaway cable can be looped or cut for that matter.
Old 07-18-2013, 07:23 AM   #9
A few pictures would help up a lot because there are a few ways to correct this depending on your set up.
-You could raise your hitch bar a hole a two , or flip it around if you need to get more height.
-Is the rear end sagging on the truck? Maybe the rear leaf springs are shot or your tongue weight is too high? Try measuring the front and rear wheel well openings before and after you hook up, this will tell you a lot about how your WD is set up.
- The bounce you experience could be caused by your shocks being worn.
I switched from an 08 F150 to an 09 F250 and the only thing I had to change was the amount of tension on the bars due to higher rated springs on the truck so it didn't sag as much. The only time my chains ever drag is when I am going up an incline from a level surface.
If you posts some pics we may be able to help.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 07-18-2013, 07:32 AM   #10
If your chains have dragged on the road and show any wear, they should be replaced or at least replace the links that are damaged with links of the same load rating.
Old 07-18-2013, 05:58 PM   #11
steeleshark2's Avatar
I have had np issues with mine. I had a standard curt wdh and now an Equilizer. Can you take some pics of it hooked up and post them?
steeleshark2 is offline   Reply With Quote
Old 07-21-2013, 03:04 AM   #12
Just a member
kandl's Avatar
Not so fast...
Round bar Reese DC with the FR inverted lower mount coupler. When we purchased the TT a couple of yrs back I specified the trunnion WDH. Was advised that the trunnion config was on six-week back order (that's half the RV season in this neck of the woods). We opted for the round bars and thus far haven't looked back. No clearance issues in over two yrs and 14K km of travel and the DC setup works as advertised with this config.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
