Old 05-12-2014, 08:23 AM   #1
TheFlagGang6's Avatar
2wd excursion with open differential.
So I've finally found an Excursion I'm considering purchasing for a tow vehicle, but it may have an open differential. I generally prefer limited slip though. I don't see an issue generally, but then again twisting into some campsites could be a problem. Any thoughts? I assume I could have a limited slip differential put in it.
TheFlagGang6
2008 Flagstaff 831QBSS
2005 Ford F150 FX4
2005 Ford Excursion Eddie Bauer 6.0l Diesel
TheFlagGang6 is offline   Reply With Quote
Old 05-12-2014, 08:36 AM   #2
Bryce's Avatar
The Excursions probably have a good bit more weight in the back to assist with traction, but I've seen more than a few nose heavy diesel Super Duty trucks with open diffs stuck on wet grass.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 05-12-2014, 08:37 AM   #3
We have installed many, look at the tag on the diff. A limited slip will say ie. 3L73 instead of 3.73
Also typically the code will be a letter and number on the door
we have used the powertrax in a few plow trucks with good luck plus you only have to remove the spiders not reset the ring and pinion
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 05-12-2014, 09:21 AM   #4
Thanks for the input. I agree it's got some weight on the rear axle. I just don't want to get this thing stuck!
TheFlagGang6
2005 Ford F150 FX4
