Closed Thread
Old 01-07-2019, 12:57 PM   #21
3/4 ton advice
Originally Posted by koller1509 View Post
While I agree with what you are saying, the overall lifetime cost of a diesel is higher for the first few years of ownership, but many guys put 300-400k miles on these trucks and many keep a diesel for a longer period. For the people in these two groups, the lifetime cost of the diesel is much lower. In my case, I would trade gas trucks every 2-3 years, but with my diesel truck I am planning to keep it for 10+ years.
You know I would have definitely agreed with you 10 years ago. But Iíve used the Chevy 6.0 towing, and the 6.4 for the Ram. We had a 2005 Ram 2500 with a 5.7l and it was a disaster towing. But these two motors and I think the Ford 6.2L is similar, are just freakin stout and thatís a combination of gearing, computer controls and advancement in engine technology. I think any of those trucks would surprise you how long they might run and 350000 miles I think is an easy mark for these trucks. Now in defense of the CTD we know they will run over 1000000 miles but I guarantee I wonít be driving that one. Haha so your analysis still works outside of the fact that I canít seem to keep a truck more than 3 years until I find a new toy.
But I hope this Ram might end that sad fact for my DW or fun fact for me or wonder from my friends, by keeping this one 8-10 years.
Weíll see.
Ps when I start that Ram up and hear that Cummins rumble, thatís just feels really good for a 58 years old guy. Canít chase the Ladies anymore so I just drive my truck.
MikeRP is offline
Old 01-07-2019, 02:05 PM   #22
Grammar Pedant
67L48's Avatar
Originally Posted by stealth2715 View Post
Most people buy way too much truck just to feel safer. [...]
Disagree. Certainly some do. I don't agree that most do.
I see far more people buying more truck than they need to future-proof themselves against potential RV upgrades in the future.
There's also laziness. If I get a 1/2 ton to tow a 7,000 lb trailer, I actually have to think about my payload and towing set-up. If I get a 3/4 ton, I only have to do a rough calculation. If I get a 1 ton, I don't even have to consider what I'm towing back there. That's less about being safe and more about me being lazy.
So, yeah, safety buffer is a consideration. I don't see it driving most of the decisions.
To the OP, why 3/4 instead of 1 ton? New, a 1 ton will only be around $800 more than a 3/4 ton with tow package. You get higher payload and other ratings with a 1 ton.
Good luck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline
Old 01-07-2019, 02:16 PM   #23
Canadian Member
Originally Posted by dbctmc View Post
Planning to upgrade my tow vehicle (2010 F150 SCrew 4x4 w max tow pkg) to 3/4 ton gasser. TT is 2014 Coachmen FE LE 31BHDS, 35 ft long, approx. 8000# as towed. I been fairly satisfied with even the old 5.4 as far as powertrain goes, so I am considering all 3 mfr.s trucks equally. I am wondering if anyone out there has experience towing a similar TT with two or all three of the 3/4 ton trucks (recent models) in terms of handling the trailer on the interstate with semis, crosswinds, etc. to see if they are going to be equal in that regard. Thanks,
David
A 3/4 ton gasser will do great with an 8000# TT.
Choosing between a 1/2, 3/4 or 1 ton is a matter of payload capability. The weight you'll be pulling (as opposed to carrying), where you'll be towing and how often, determines the engine size, type (gas vs. diesel) and drivetrain you need. I typically recommend a diesel engine if you're pulling more than 11,000# but if you're towing full time or regularly towing in the mountains, a diesel would be preferable even with a trailer that's lighter than 11,000#.
2019 Rockwood Signature 8290BS
itat is offline
Old 01-07-2019, 02:43 PM   #24
I towed a TT with two different trucks and a 5th wheel with two different trucks
1st was a 2010 F150 5.4 3.73 Max Tow. TT, 31' @7200 lbs. It was just okay most of the time. 5.4 is a dog period. TT was not designed well with the axle too far forward. That caused some waggleing. Never white knuckle but it moved the F150 around a bit. Used an EQ with 4 pt sway built in.
Same TT with a 2012 Ram 2500 Cummins 3.73. rock solid. Even though I could see the TT waggeling it didn't budge the Ram 2500 CTD.
Moved into a 9300 lbs 5th wheel with the 2012 2500 CTD. An absolute joy to tow with in Oregon and the PNW and out to Montana and back.
Now tow the same 9300 lbs 5er with a 2018 Ram 2500 6.4, 4.10. Not near as much joy as with the CTD. However I don't have to deal with getting diesel or changing fuel filters, or draining them, worrying about water in the fuel, long warm ups in the winter and emissions clogging up.
Now the 2013 and up diesels are much nicer as a DD. But I couldn't justify the extra $9K when I only tow 4,000 miles a year and only put 9,000 miles a year on the truck.
My 2018 6.4 gets terrible mpgs towing. The fuel tank is also 3-4 gals smaller. I get around 8.5-9 towing. Got 10.5-12.0 with the CTD. It's not really the fact that I don't get as good of mpg's, it's the fact that combine that with the smaller tank and I'm about 100 miles on a tank in the hole before starting. 100 miles is a serious amount when taking a long trip.
goduc is offline
Old 01-07-2019, 03:12 PM   #25
2rad4u is offline
Old 01-07-2019, 03:28 PM   #26
Multi-Slacker
Our TT us 33'0" long with a GVW of 8818 lbs and has been towed by two trucks: a '14 Tundra and an '18 Chevy 2500HD. They both pull and stop well but the Tundra had a 1400 lb payload and the Chevy has a 3300 lb payload. Happier with the Chevy.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is online now
Old 01-07-2019, 05:12 PM   #27
BigH's Avatar
I couldn't find much evidence of folks making it to 200k without issues related to emissions when I was gathering information to buy. Its interesting to me that folks used to buy a diesel for life...today you can find used diesels nearer the end of the warranty all over the place.
Anyway, it looks like the OP has done his homework and wants a gas truck. If reliability is the number one priority I would say that's the best choice.
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline
Old 01-07-2019, 05:46 PM   #28
If I buy a 3/4T in a few years, I will be looking at the new Chevy with the new 6.7L gasoline engine that's coming out. Not sure I would buy it in its first 2 years of production so maybe the 2022 model year.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now
Old 01-07-2019, 06:07 PM   #29
koller1509's Avatar
Go look at the Cummins forum - a lot of heavy haul guys getting 300-400k on stock trucks with no problems. Its just like the RVs, you only hear about the bad ones, not all the good ones.
One other thing, guys buy diesels, tune them and mod them, then end up breaking stuff and then want to bad mouth the manufacture - if you want to play, you gotta pay!!!
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline
Old 01-07-2019, 06:30 PM   #30
BigH's Avatar
I looked on there, the Ford forums and the Duramax forums. Sure there are guys that drive for a living and get some high miles but that is the best case scenario for 'good odds' on everything working. That group is on the other end of the spectrum from the complainers of 'bad luck', but the middle ground didn't look that great either. How about the guy with the GM 6.0 gasser that just turned 500k hauling...He replaced an alternator and two water pumps (or vise versa).
Its pretty telling when you find threads from folks asking about pulling a 10k trailer on the diesel forums and the diesel owners telling them to go gas...
Most telling is my co-worker who supervised a fleet of diesel trucks and switched them over to gas because of down time issues related to emissions. Or the local sewer and water company that switched all the Cummins over to gassers.
I really wanted a diesel and looked for evidence to support my 'want'. I had almost one year to research it because of getting rid of a lemon law Ford truck. I could have written the check for the diesel same as the gas truck but my number one priority in a vehicle designed to get my toys from point A to point B is reliability and you're not going find a great many folks willing to argue that the newer 'DEF' complicated diesels will win that comparison.
18 Vengeance 28V
BigH is offline
Closed Thread
