Old 08-03-2014, 10:41 PM   #31
Maybe the 4" axle tube is why the later model trucks are spec'd to handle more rear axle weight than my 2003 model F250.
Not that it really matters to me. I'm not going to overload it with a medium size fifth wheel anyway.
Bamaman is offline   Reply With Quote
Old 08-04-2014, 12:08 PM   #32
Bryce's Avatar
I looked up parts for a 2001 F-350 on rockauto.com and they showed 4-1/16" U-Bolts on Duallys and 3-5/8" U-bolts on SRWs. they might not be right though (not their first time)
I'm with you.. I'm not going to over load my truck with a 26' TT, even though, I'l over in GVWR, my axle ratings are all under and GCWR is under. the 3.5" axle has lasted over 13 years and 211,000, so I'll be fine.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 08-04-2014, 12:31 PM   #33
SKnight's Avatar
One of the primary reasons for larger axle tubes is the increased power output of the engines. On acceleration the pinion gear tries to climb the ring gear (Why the front end comes up on take off.) and that rotational force gets transmitted through the axle tubes to the spring perches.
Larger axle tubes allows for larger perches and more contact area to weld thus vastly increasing strength. When power started taking off early in the 2000's the need for stronger parts to handle that power came forward. Payload and towing increases followed suit.
Old 08-04-2014, 12:44 PM   #34
GreenImp's Avatar
Send a message via MSN to GreenImp
My TV is an '04 GMC with Duramax and Allison (90k miles). The drivetrain is all stock and I see no need to change that. The only thing I wish to be different with my truck is a quieter engine like the newer ones...but I sure as hell ain't gonna spend $30k (roughly the difference between value of mine and a new one) for a quieter engine.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 08-19-2014, 05:11 PM   #35
jevanb's Avatar
One way to quiet it down is install a lift pump as the CP3 will not work as hard and the injectors will love it also, all lb7's really need it
semt from my s4 mini
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 08-19-2014, 05:43 PM   #36
2012 F350 6.7 PSD. No mods or add ons. It runs and pulls perfectly. Would rather spend the money on camping and traveling. I did buy a window shade for it if that counts.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 08-23-2014, 07:13 AM   #37
Thumbs up
'96 2500HD CTD 4x4 CC LB SLT, Goerend tranny with 3disk TC, 4.10 axle gears, 265 Dueler AT/Revo 2 tires, BHAF, (BigHonkinAirFilter), straight piped, ISSPRO boost/pyro/tranny gauges to keep track of the vitals, KillerDowelPin tabbed, 3k GovernorSpringKit, #5 TST fuel plate (270 hp/675 ft-lbs), 16*, MagHytec deep trannypan, Darin'sSteeringStabilizer, PSC gearbox, Diehard Platinums (these are 'killer' batteries and will crank the Dodge even under severe circumstances, like cold and having sat for a while). Currently at 300+k miles and counting
2002 Sandpiper Sport T28
1996 Dodge Cummins
Iceman_RNR is offline   Reply With Quote
Old 08-23-2014, 02:21 PM   #38
jevanb's Avatar
^^^ NIce , buddy at work has the exact same truck and he made 855hp on fuel and outran another coworkers 1200 bored bandit motorcycle, when he sprayed. They had a bet and our ramp at work is pretty big.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 08-23-2014, 02:51 PM   #39
Camper Less Camping
Cajun Po-Boy's Avatar
I'm a former 1250S Bandit owner...fast bike, impressive that a 7K truck dragged that *****!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-23-2014, 03:22 PM   #40
jevanb's Avatar
Randys bandit has 130k since he bought it new, he knows how to ride fast and was taken by suprise
Sent from my SCH-I435 using Tapatalk
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
diesel
