Old 02-29-2016, 12:39 PM   #61
CWSWine's Avatar
Ok, so I changed from 200 to 250 like says on the website and made the total even lower. I have B&W turn over ball and all three pieces are close to 200 lbs so that what figure I always use. Empty 5er pin weight still is 2250 how much grows loaded depends on loading and floor plan. My 5er the more added to the fridge, pantry, bathroom and bedroom the lower pin goes.
You're adding approximately 650 lbs. to the truck. You have 2,090 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 8,360 - 10,450 lbs.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-29-2016, 12:47 PM   #62
CWSWine's Avatar
Here is real world
Dry Pin Weight 1950
Yellow sticker on 5er 10,025
2013 Chevy 2500 HD Diesel with 2475 payload GVWR 10,000
2015 Crusader 315RST 5th Wheel - Scale Weight 11,380 Pin Weight 2740 Lbs
Actual Weights - Fifth Wheel Weights from CAT Scales - Towing Planner
