Old 02-27-2016, 08:49 PM   #21
In the previous discussions one point seems to have been missed - check out the size of the brake system 3/4 ton vs 1 ton. With the 1 ton you will have better stopping power which could make quite a difference in case of emergency.
grandpacsf is offline   Reply With Quote
Old 02-27-2016, 08:54 PM   #22
davel1971's Avatar
no difference in brakes between a 3/4 ton and SRW 1 ton
David & Lynn
Old 02-27-2016, 09:08 PM   #23
The_Rhino's Avatar
Yes, I think that most 3/4 & SWR 1 tons share the same HD frame, brakes, axles, etc. and this is why I think it's crazy that more & more 1/2 tons have tow ratings (but not payload) approaching 3/4 tons...
For a number of years I did construction-related work & NEVER felt comfortable hauling heavy equipment behind 1/2 tons, even though they were "rated" for the GCVW... When the roads & conditions were bad the HD trucks handled the weight better.
Like I said earlier, if you want to soften the ride, add some sand bags. After adding a fiberglass cap & some sand bags this winter I didn't see any change in MPG on my daily commute & my ride is less bouncy...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 02-28-2016, 09:04 AM   #24
MCTroy
Our 2011 3/4 ton Ram Big Horn has a light load setting for the tires. We can lower the tire pressure in the rear tires to 45 psi and not get a low tire pressure warning when the setting is turned on. This really helps the ride. Of course when towing we have to pump the tires back up.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 02-28-2016, 09:58 AM   #25
I lower my non-towing pressures as well. I run mine at 60 front, 50 rear unloaded; I need the extra pressure in the front to carry the weight of the diesel. Another way to soften the ride........
David and Vicki
7 year old Springer rescues Sydney and Piper
2014 GMC Denali 3500HD Dually Crew Cab Duramax/Allison stock
2016 Dutchmen Denali 287RE "The Dog House"
Eaz Lift WDH 1400# w/ Blue Ox 2 1/2" trunion
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 02-28-2016, 10:16 AM   #26
The F250/F350 longbeds are horrible to ride on concrete highways when unloaded. They shake/resonate horribly between 70-79mph but faster and slower speeds alleviate the problem.
Also, there are thousands of posts on Ford Super Duty forums since 2000 with a persistent rear end hop at 45mph that has plagued the Fords and is likely due to too much flex in the frame.
Rear End Hop
Rear end bounces @ 40-45 MPH - Ford Truck Enthusiasts Forums
Wheel hop/ back seat shake - Ford Truck Enthusiasts Forums
I have a '15 F350 172" wheelbase with longbed. It rides like a dream on asphalt highways but segmented concrete gives my kidneys a jarring and my 5'1" DW needs a 5 point harness so as not to hit the roof.
500-800 lbs of dead weight in the truck bed helps smooth things out when unloaded.
When towing, the issue is not a problem. We often unhook when we camp and like to explore new areas with our truck so using the truck only when loaded is not an option.
Skyliner is offline   Reply With Quote
Old 02-28-2016, 10:44 AM   #27
A truck is just that 3/4 or one ton will tend to ride harder, but when loaded will soften its when people add airbags helper spring and such the ride suffers, these trucks are designed with a load in mind, most 1/2 ton trucks ride like cars because that's what they are in a manner
Clarici l is offline   Reply With Quote
