07-09-2014, 06:06 PM
3.42 or upgrade to 3.73 gears
We picked up a Rockwood Windjammer 3001W in April to pull with my 2013 GMC Sierra 1500 Ext. Cab. It has the HD towing package, 5.3 V8, 6-speed tranny, 3.42 gears, and the GVW is rated 15,000 lbs. We weighed the whole rig on the way home from the dealer and tipped the scales at 13,060 lbs with two people and a full tank in the truck. I figure we have added between 500 and 750 in gear, but have kept a very close eye on weight. Currently I get from 8.5 to 9.5 MPG when towing around Texas and have had minimal issues pulling so far; I use the Tow/Haul setting most of the time. We are planning to pull to Oregon next year via Yellowstone (4,000 miles) and wondered if it would be wise to move to 3.73 gears for the mountains. I am adding the K&N cold air system and mandrel bent dual exhaust to boost power...and hopefully fuel economy also.
Has anyone out there made this swap, and did it help/hurt? I know my around town regular driving MPG would probably take a hit, but would it actually be better MPG when pulling with the lower gears?
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
07-09-2014, 06:15 PM
If my thinking is right, 3.73 would give you slightly lower mpg all the time. Changing the gears would be very expensive if its 4wheel drive.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
07-09-2014, 06:50 PM
I have a f250 with the 5.4 and 3:73 gears in a 4X4, I tow a 3065w Windjammer . I get 10.5 mpg at best, that's keeping the speed under 60mph. I am also thinking of some mods to get a little more power. I agree changing the gear could be an expensive venture. Sounds like a good reason to get that diesel .
07-09-2014, 07:06 PM
2-Wheel drive
I haven't called the GMC dealer yet to get pricing, but mine is a 2WD so just the rear gears and some adjustments to the computer should be all that is required. I think pulling up the Rockies may tax the 5.3 with 3.42 gears; although I have pulled up some pretty good grades recently with no real issues.
07-09-2014, 07:15 PM
It's much cheaper to just down shift and slow down a little. Unless you plan on spending a lot of time in the mountains over the next few years, it is not worth it to take the hit in mileage when not towing.
07-09-2014, 07:47 PM
I am a shop foreman at a GM dealer and own a 13 Chevy 1500 and a 08 Chevy Dmax. Going to a lower gear will hurt more then help. You are at your best setup with the engine, trans and gear you have. Also do your research on the cold air setup because some of them will cause issues with trans and may cause check engine lights. With that much weight I would upgrade to a diesel if you can. I pull 15k+ with my dmax at 70mph and get 15 to 16mpg. Whatever you do don't program you ecm with a power up programmer. It will void your warranty and even if you take it off we can still tell and is required to report to GM for warranty repairs on engine.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
07-10-2014, 08:27 AM
changing gears
Excellent advice and just what I was looking for by posting. As I said, I use the Tow/Haul selector for most driving except on really flat stretches of road. I am not going to look further about the gear change, as I suspected the loss would be more than the gain and now it is confirmed by those with more experience and knowledge than I have. I have heard that the cold air sometimes doesn't help, but thought I would give it a shot to see. I am keeping all of the OEM stuff to put back on if needed. I am going to an upgraded exhaust with mandrel bent tubing and cat-back duals to pick up a little better breathing. The truck is only one year old (see photo), and upgrading to a new one is not in the cards (or budget) at this time. We picked up the trailer based on our ability to pull with the 1/2 ton, so we are still very pleased; I was just checking to see if something I could do would make it even better.
07-10-2014, 08:47 AM
Yes, you will have to go slow; sometimes it is hard to be patient on a 4,000 mile trip; the towing days can get long. You may be screaming up the grades at 4,000+ RPM; perhaps in 2nd gear. Just be prepared for it. Watch your transmission temperature. Some of the grades are steep and they go for miles.
It's wonderful territory though. Take your time and enjoy it. Have fun!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
07-10-2014, 09:02 AM
Phat Phrog Stunt Crew
I was pulling a Lacrosse 301rls about the same size with a 2008 GMC 1500 with a 373 / 4 speed. I upgraded to 2013 Chev 1500 with a 342 / 6 speed and it felt better than the GMC. It was shifting a little more when needed but there were no large jumps in RPMs like the 4 speed plus I got about one MPG.
2014 Wildcat 327ck
07-10-2014, 09:06 AM
Incheon, S. Korea
Why do you want a cat back system? The exhaust gasses have cooled significantly at that point and take up much less volume so bigger pipes aren't really needed. Just sayin'
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
07-10-2014, 09:12 AM
A numerically higher axle ratio will help you off the line. But if you're already pulling away from stoplights OK now, you don't need any more help in 1st gear.
At speed, a numerically higher axle ratio will help you hold a specific gear longer before a downshift is needed. With older 4-speeds, this was a bigger deal because a downshift meant a huge increase in rpm, and potential drivetrain shock (?). But with the modern 6-speed transmissions (or more), the rpm jump is much less, and is also better controlled.
I would hate to make an axle change like this, and never know if you would have been OK without it. Taking this 4000 miles trip is not going to hurt your truck, and you already said you've already handle some pretty good grades. Take the trip as is, and use it to decide whether you want to make the change. Until you have a concrete reason to change, don't bother. Fact is you are still at least 1000 lbs under your GCVWR.
07-10-2014, 09:21 AM
Once you go west of the TX Border, you will find a basic truth: All the "Mountains" you have driven in in TX & East of the Mississippi are REALLY overrated hills
When you hit NM/CO/UT/WY and make those 3% grade climbs for 10-20 miles only to come to the final twisty-turny 7% 10 mile last leg to the crest...THEN you know what a mountain is
You will learn to drive the extra 60 miles to the pass, rather than taking the more direct over-the-crest route
Just go slow and take breaks, keep your truck apps on and watch your tranny/oil/water temps. If you have to pull over a big'n (classified as a 9K or more ; best do it in the morning, late evening, or overnight if you can. Summertime temps in the high desert can easy be 110 deg with blacktop surfaces being 120 deg.
I have a couple of friends that have similar rigs to ours towed by a F150 EcoBoost; they are not reporting any problems but gas milage is @ 8-9mpg-7 on the steeper grades @ 4K RPM.
(We lived in NM for 10+ years and towed a Coleman Niagra Popup behind a pretty much stock Ford Aerostar minivan - the big popup was probably right at the Aerostar's GVWR-- or over we did not have any problems in the mountains though)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
07-10-2014, 09:54 AM
Hey, BamaBob,
I have family in the Huntsville area. Never heard the "HuntVegas" thing, although I haven't been "down home" in a while. What's that about? Casinos taking over?
07-10-2014, 10:19 AM
CAT BACK
BigBaron - love the Carson photo! I am mainly interested in the better exhaust system. Mandrel bent is smoother flowing than crush bent from the factory or what you get from local muffler shops. Should pick up about 10 HP per several of the reviews I have read; better bang for the buck than going full header-back duals with an added cat needed.
