Old 06-14-2013, 07:59 AM   #1
avolnek's Avatar
3rd Gen Dodge Cummins Towing
I'd like to hear from and see pictures of fellow campers pulling with the 5.9 cummins. What speeds do you tow at? What's your RPM at that speed? What gear do you pull in? What do you pull? What is your average fuel mileage pulling?
ID:	33100   Click image for larger version
Name:	daisy duke 2.jpg
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 06-16-2013, 07:19 PM   #2
mike54's Avatar
I tow a 35' TT about 8800 lbs with a '05 Ram CTD 3500 60-63 mph 1600-1800 RPM in OT trans temp holds about 187 degrees if not in traffic I'll have the cruise on
Mike & Marsha
2011 Signature Ultra Lite 8319SS
2005 Dodge Ram 3500 5.9 cummins diesel
http://www.facebook.com/WestAllisSunshiners
mike54 is offline   Reply With Quote
Old 06-16-2013, 08:56 PM   #3
07 ThunderRoad's Avatar
We have a Dodge Cummins 2500. Air Lift 5000, with the frame rubber bumper inside the air bag, the Trail Air pin box, and the Helwig heavy tow rear sway bar. Only towed from dealer to the seasonal site, 75 mi. Coach towed much better than our old TT. Our coach is a Prime Time Sanibel 3600. It's 40' long and 12,500 lbs empty.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 06-16-2013, 08:59 PM   #4
transamz9's Avatar
Here's my little tow that I pull will my '05.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 06-17-2013, 07:45 AM   #5
avolnek's Avatar
Thanks all! When we purchased the truck I really wanted a stick and my wife really wanted an auto so she could drive it... seeing as I was trading in a brand new 1/2 ton hemi and she was reluctant to trade anyways I figured I'd better go along with her...
What are you guys averaging at those speeds mileage wise? I appear to be following suit with the majority of you with that 60-65 mph range... I have hand calculated right at 10mpg over a handful of trips with different trailers tagging along.
Transam, that is an awesome looking rig! Love seeing these 5.9's tuggin a train like that! Very clean looking truck! What kind of tires are those? How do you like them?
Old 06-17-2013, 07:53 AM   #6
mike54's Avatar
I average 12–13.5 mpg which is an improvement than towing with the 2500 Chevy 6.0 gasser 7-8 mpg I had before this Dodge
Mike & Marsha
Old 06-17-2013, 12:11 PM   #7
transamz9's Avatar
Thank you, and the tires are Mastercraft C/T 285/70/17. I like them really well they are just a little noisy at highway speeds.
2006 EZ GO 6" lift
Old 06-24-2013, 08:16 PM   #8
Here is Mine!
bignugget is offline   Reply With Quote
Old 06-24-2013, 08:47 PM   #9
my wife and i are looking at upgrading to a larger fifth wheel with a large bunk house.. right now we have a 25 foot puma and looking at the 2014 crusader 360BHS the dry weight is about 12400 and after we load it it will be pushing 13500+. my question for all members is i have a 2006 dodge 2500 with the cummins 2wd is this two much for the truck we do live in louisiana and will not be hauling in the mouintans but maybe once a year but i dont want to invest in this kind of unit if i cant pull it. any sugestions?
sbreen is offline   Reply With Quote
Old 06-24-2013, 08:47 PM   #10
semi-senior member
denandra2's Avatar
I get between 12 & 13 at 60-65, most usually I try to keep it at 63, just seems to be its sweet spot. I have the Trailair Tri Glide and it was a great improvement over a stock pinbox. I use the tow/haul mode in the normal Drive/OD position
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
