Old 08-04-2010, 02:38 PM   #1
azwade
5er Hitch Installation Question
This may sound silly (and probably is) but does 1/2 in off center (side to side) matter on a 5th wheel installation? I just checked the installation performed on my truck and found that the 5th wheel hitch king pin is off center (to one side) by inch. Should I squawk about it? Also, the hitch is 2-1/2 inches in front (closer to the cab) of the rear axle center.
azwade is offline   Reply With Quote
Old 08-04-2010, 02:46 PM   #2
I would not worry about being off center from side to side by a 1/2 inch. As for it being 2 1/2 inches in front of the rear axle that is to add weight to the steer axle which is fine. I have had hitches installed in two different one ton dually units and they were both in front of the center of the drive axle.
Enjoy your rig - go camping!
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 08-04-2010, 02:55 PM   #3
azwade
Thanks Emptypockets.. I knew that the hitch had to be installed in front of the axle, I just did not know if 2-1/2 inches was normal. Thanks for the prompt reply. Great forum...
Old 08-05-2010, 10:59 PM   #4
Mr. Black's Avatar
I run 2.5 inch forward on mine even with a shortbox. The half inch side to side really isn't going to hurt a thing, but I am anal enough it might bother me lol. As long as the rest of the install is sound then leave it alone.
Depending on the brand and the rails, you might be able to go out right now and knock the thing over a 1/4 inch. Some really are that sloppy.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
5er
