Old 08-15-2012, 03:37 PM   #1
Brigitte
boubou's Avatar
5h wheel overnight parking while hitched up
Other half insists on bring front jacks on 5th wheel) down while hitched up overnight (as well as rear) for stability.
I wonder if that put strain on the pin?
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 08-15-2012, 03:52 PM   #2
Witch Doctor's Avatar
When I do not unhitch, I always put down all the gear just enough to stabilize the unit from movement. I really do not pick it up off the plate on the fifth wheel but it will help with the movement. I have a Rockwood 31'. The rear helps the most, but I have not found any damage by doing it.
Old 08-15-2012, 03:54 PM   #3
TURBS's Avatar
How would it put stress on pin?
Old 08-15-2012, 03:59 PM   #4
Herk7769's Avatar
Brigitte,
For what it is worth, I disconnect even for short overnight stops.
The reason is that my fridge is not level when connected to the truck.
Operating the fridge that much out of level for hours will most likely overheat the absorption system resulting in eventual hardening of the boiler and coolant leaks.
Operating out of level when traveling is not a problem as the liquid coolant will "slosh" itself back down into the boiler keeping it from overheating.
Trying to "lift" the truck with the front landing gear to level the camper while connected will most likely over stress the gear drive and eventually break a tooth. Then you will be stuck with the landing gear inoperative. It also will not do your hitch any good either.
HAM CALLSIGN - KC3FFW
Old 08-15-2012, 04:06 PM   #5
Originally Posted by herk7769 View Post
Brigitte,
I gather that your trailer is not level while towing? I guess we're lucky, our fridge is in the back wall and the trailer is also level while towing. We never unhook, just run the landing jacks down to stabilize and don't even run the rear jacks down.
Old 08-15-2012, 04:35 PM   #6
Brigitte
boubou's Avatar
Yea, trailer not level. Dealer said close enough and i say not. Will look into this when I get back home. In the mean time, I guess I need to un-hitch. Not a big deal, just pull the bar and drive off lol.
Thanks guys! As always, you come the rescue!
Superglide 2700
Timbrens
Old 08-15-2012, 05:43 PM   #7
If you are happy with the 1/2 Ton put Air bags on it to level. Youroo!!
Old 08-15-2012, 05:56 PM   #8
Brigitte
boubou's Avatar
Pretty happy, but problem is truck is too high so airbags wont't lift the 5th wheel, just the TV backend. Need to get the 5th wheel axles flipped or something....
Going to call manufacturer and get their seal pf approval prior getting anything done tho. In writing
Superglide 2700
Timbrens
Old 08-15-2012, 05:57 PM   #9
Brigitte
boubou's Avatar
Soooo, took a whole 2 minutes off my evening and un-hitched and level. No more stay hooked up for us until 5th wheel is more level.
Thanks again
Superglide 2700
Timbrens
Old 08-15-2012, 06:18 PM   #10
Is the truck jacked up?
