Old 01-03-2015, 10:29 PM   #1
Canadian Member
itat's Avatar
5th Wheel and 5'6" Truck Bed?
Just curious if anyone is towing a 5er with a 1/2 ton with a 5'6" box?
Previous owner of my TV (2009 F-150 with Max. Tow pkg. - 11,200#) used it to tow a 5er and left the rails in the bed. There is a small dent from his 5er touching the cab roof.
As my signature says, I'm researching for my next RV. I've only considered TTs because my TV has a 145" WB, 5'6" bed and 7200# GVWR. Is a 5er even an option?
If you do this, do you use a slider hitch or Sidewinder type kingpin?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 01-03-2015, 10:59 PM   #2
asquared's Avatar
You have a few weak points here. Payload is going to be your severely limiting factor. Also have to look to see how much weight your rear axle can handle. Remember that the loaded pin weight on a fiver will be 20-25% of the loaded fiver weight.
What does your tire loading sticker inside your drivers door say for payload (it will read cargo and occupants should not exceed x lbs)? Best thing you can do is load it up ready to camp and go weigh it. Put front wheels on scale pad one and rear wheels on scale pad two. Take total truck weight and subtract from truck gcwr to get your adjusted towing capacity. Take total truck weight and subtract from gvwr to get your available payload. Take the rear axle weight and subtract it from the max rear gvwr to see how much room the axle has. You will quickly find out how limited you are going to be here.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 01-03-2015, 11:04 PM   #3
Denver, CO
garbonz's Avatar
Maybe a very small one.
2017 Fuse 23T
Old 01-03-2015, 11:17 PM   #4
Canadian Member
itat's Avatar
Thanks for the quick replies. You are confirming my concerns. I know payload will be my biggest shortfall.
I upgraded to LT tires and added a leaf spring on each side of the rear which made towing the 5200# Roo much more solid, but that doesn't change the max. payload that's still limited by the stock axles, bearings, wheels, etc.
Old 01-03-2015, 11:22 PM   #5
Flagstaffer06's Avatar
Everyone else mentioned payload which they are correct.
With that being said, to answer your question. I believe for the 5'6" bed the two best options are the Pull-Rite sliding hitch or the sidewinder.
Personally, if I did it, I would have the fixed hitch and a Sidewinder pin box.
I did months of research on back and forth thinking the same thing for next camper. I was limited on payload too and I had the 5'6" bed too. In the end, I went with a travel trailer again.
Alot of good things though I have heard about the Sidewinder and dealers that know and understand them say the same thing. Some dealers I talked to never heard about them or wanted to sell me a sliding hitch and the sidewinder. It was pretty bad.
Anyway, do your research like you are and maybe talk to some people that are towing a 5er with a truck with similar specs to yours. I guarantee someone is pulling a 5er on here with that setup.
2012 Keystone Sprinter
Still sticking around for the good people and advice.
Flagstaffer06 is offline   Reply With Quote
Old 01-03-2015, 11:46 PM   #6
B and B's Avatar
I tow a Rockwood with a Revolution hitch. Works great!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 01-04-2015, 10:10 AM   #7
Ksilvi's Avatar
We towed a 2014 prime time crusader 295rst with a 2009 f150 5'6" bed and NO SLIDER hitch. We did a test & SLOWLY did a 90 degree turn just to double check the clearance and it CLEARED. We originally spent too much on a super glide hitch because we were told we needed it, but found out afterward that a Reese none slider worked just fine.
2014 Crusader 295rst
2014 F150 Fx4
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
Old 01-04-2015, 10:13 AM   #8
Ksilvi's Avatar
There are MANY 5th wheels on the market that have maximum turn radius front ends now. Crusader, all Heartland 5th wheels and many many more. An easy way to tell is by the shape of the nose. Then double check by reading through the rig's features.
2014 F150 Fx4
Old 01-04-2015, 10:16 AM   #9
BamaBob's Avatar
X2 Both Brian and I are very happy with our sidewinder (BTW we have a 6' bed and you can STILL dent the cab if you do not have a active sidewinder )
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-04-2015, 10:17 AM   #10
davel1971's Avatar
every 5th wheel has a different cap shape. Even if you test and clear in a parking lot, doesn't mean it will clear on a slight slope with the trailer leaning to the side slightly. Be cautious
David & Lynn
5th wheel, bed, truck, wheel
