03-14-2014, 07:51 AM
5th wheel hitch 2015 chevy
I ordered a new 2015 chevy 2500 yesterday(lucky me). I'm already looking for rails to order so I can install my reese slider in the new truck as soon as I receive the new truck(it will be camping season here in CO by then) The problem is that I don't see anything for a 2015 yet. Do I need to have my camper dealer install one or has anyone found the info that I can't?
thanks for your feedback,
Mike
03-14-2014, 08:09 AM
Somewhat right of center
I'd imagine the frame is the same as at least 2010 and above. I have a 2013 2500 and am willing to bet whatever fits mine will fit yours.
Last year I was in the same boat as you. I bought the truck in March 2013. When I bought the fifth wheel camper in May, the RV place ended up putting on a hitch that fit a 2012. I don't see why that wouldn't apply now unless GM overhauled the whole design.
Also, I was given a waver I had to sign IF I was going to install the 5th wheel hitch myself for liability reasons. Screw that, I let them do it. I figure they install these things for a living so at least it will be done right, if not, I can go after them if something goes wrong.
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
03-14-2014, 08:29 AM
Previous truck was 2006 Chevy 2500 and fame had to be drilled. Don't know when the frame was changed but my 2013 has a box frame and uses existing holes. I had the bed drilled by the guy who sprayed my bed liner in and installed new rails myself and reused the hitch. It was very difficult to install the nuts, shims and tighten the bed bolts because of limited space. Hands were scratched up pretty good. Call etrailer. Although I don't see the mounting brackets listed separating they may have them. Congratulations on the new truck
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
03-14-2014, 05:19 PM
I looked at the '15 2500 today, what type of 5'er you going to be pulling? I'm thinking of getting a new 2500 so I have it when I upgrade my current TT in a few years
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
03-14-2014, 05:28 PM
Mike
From what I have read, the frames, engines, and suspension are the same, at least for the Duramax from 2011 onward. The changed the interior and exterior plastic.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
03-14-2014, 05:40 PM
I have a Puma 230fbs. I just wrecked my 2012 2500 and that's why I'm getting the 2015, Diesel of corse
03-14-2014, 05:49 PM
Get a 3500, it will give you more later.
Signed: been there shoulda done that.
03-14-2014, 06:21 PM
Correct on the above info
Give Cequent a call they cover all the popular hitch brands and have excellent customer service and techs.
1-800-632-3290 when they answer and ask for your account number just tell them your a consumer looking to speak with a technician about 5th wheels. Knowledgable people there to help.
Did you go with a gasser or coal burner?
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
03-15-2014, 07:19 PM
Always Learning
Try calling B&W to see if they have a Turnover Ball setup for your truck. They're usually incredibly helpful.
03-15-2014, 08:04 PM
Oklahoma Proud
Without consulting my frame measuring system, I'm almost positive that the frame is the same as the '11 tru '14. The front bumper brackets are probably a hair different though.
So any '11 thru present hitch will work on the '15s.
Fyi, no manufacturer will warrant any frame that has been welded on or had holes drilled in it. So a b&w type setup that only uses factory holes is the only type that should be recommended. I'm sure that there are others our there that use factory holes besides b&w.
MillerTime- Future Sabre Handler!!
03-15-2014, 08:25 PM
thanks, I already have a reese slider and am just looking for a rail set. The last one I installed on the 2012 truck was made for the frame and no drilling was required( except in the bed) and that is what I'm looking for again
03-15-2014, 08:30 PM
Oklahoma Proud
Should be able to use the same brackets on your new one then.
03-15-2014, 08:47 PM
I ordered new brackets for my 2013 in January of 2013 from E trailer. There were several different brackets so the are specific to a truck.
Not sure of how a turnover ball works but if it is so a goose neck can be used I would contact the RV manufacturer. Some manufactures don't recommend it and can damage a frame.
I have a Reese and reused the rails and hitch head. As I posted previously, all I needed was the frame to bed brackets.
03-21-2014, 09:08 AM
I just found that reese has updated the catalog and you' guys were correct. The same brackets will work on the new truck. Can't wait to see how she performs
