Old 01-20-2018, 12:00 PM   #1
Jmsx2's Avatar
5th Wheel Hitch a Maintenance Question.
Hi Gang. We have a new Reese 16k Slider Hitch. How do you maintain yours. Types of lubricants, lubricating locations and how often.
Thanks.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 01-20-2018, 06:59 PM   #2
M109Rrider's Avatar
I spray all the moving parts with a spray lube on occasion...thats about it. If you don't use a lube plate between the pinbox and hitch plate, I recommend it.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 01-20-2018, 07:06 PM   #3
Jmsx2's Avatar
We took her straight to storage when we took delivery. Lube Plate is a must. I've heard that a Dry Lubricant should be used on the slides and a wet lube on the mechanism.
I'm particular about maintenance. Thanks for sharing your experience.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 01-20-2018, 07:35 PM   #4
Wobbles's Avatar
You should be able to find all Reese hitch maintenance info on-line. I would follow their plan until somebody convinces you that the manufacturer is wrong.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 01-20-2018, 07:40 PM   #5
Jmsx2's Avatar
I've actually been looking online. Not very clear on what type of lube to be used in the different moving parts. Thanks for writing.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 01-20-2018, 08:04 PM   #6
Wobbles's Avatar
Call them...
Bob & Michelle
Old 01-20-2018, 08:19 PM   #7
Jmsx2's Avatar
Call them...
That's a good idea.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 01-20-2018, 09:05 PM   #8
FrankG's Avatar
A fifth wheel hitch contains a few moving parts that move very slowly only when you hitch up or unhitch. Plus the jaws that contact the pin. Grease, any grease sold at Walmart or your favorite auto store will do. If it says waterproof you are in luck. (they are all waterproof, just some more than others) NLGI 2 would be the proper designation.
Use the same stuff you use for your wheel bearings, and wet bolts.
2018 Haulin 6 x 12 Cargo Trailer by Forest River (A legal Tow )
2017 Laredo 325RL
2016 Vengeance 29V Sold
2016 Ram 2500, 4x4 Laramie CCSB 6.7 Cummins
FrankG is offline   Reply With Quote
Old 01-21-2018, 07:57 AM   #9
Jmsx2's Avatar
Thanks for writing. I kind of figures that type of Greece in the Jaws. I'm thinking a dry lube in the slides. That should minimize dirt collecting on them.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 01-21-2018, 04:33 PM   #10
DouglasReid's Avatar
We have the same hitch. there are two springs underneath the head which should be coated with grease. They close the mechanism when you are connecting.
We live in a humid climate and if you do not grease them they fail after a year or two. (ask me how I know). Other than that a lube plate on the pin and an occasional squirt of silicone lube on the slide rails and rollers and it works wonderfully.
We do find that it is necessary to remove the weight from the pin to have it slide easily. Extending the landing gear and lifting it, then sliding it rearward, then lifting the landing gear is a bit of a pain, but we do not mind. It does not take long. I usually do it while she goes in to check into the campground.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer
DouglasReid is online now   Reply With Quote
5th wheel, hitch, maintenance, wheel
