Old 03-17-2013, 05:38 PM   #11
QCCowboy's Avatar
Not sure how the Patriot hitch recommends setting the height, but I am guessing that to determine the proper setting you will need to take a few measurements with both the truck and trailer on level ground. When I installed my Reese Elite Series I had to measure the bed of the truck from the ground, and the kingpin plate height from the ground, while both where on level ground and my trailer was leveled out. After subtracting the two numbers and adding 2" to the total (for compression) I was able to determine which holes to use when setting the height of the hitch itself.
If you look at page 12 of the PDF in the link below it will give you an example.
http://4wheelonline.com/images/REESE/pdf/N30142.pdf
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 03-17-2013, 05:40 PM   #12
John McClain's Avatar
I am on my 3rd 5th wheel now and 2nd truck .I have had to mod all three 5th wheels to work from flipping axils to welding square tubing between the frame and the suspension. what ever you do make sure you have 51/2 to 7 inches between your bed rails and the trailer . I do a lot of dry camping in Pismo beach and offroad parks my trailers go threw a workout every trip . My last 5er hit my truck bed rail coming out of a gas station on a steep down hill angle. I was lucky only $1300.00 to get them fixed .
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 03-18-2013, 07:41 PM   #13
coderider's Avatar
X2 went through the same exercise with my Reese when we got our new F350. Once I had double checked all the measurements, adjusted the hitch height before placement in the bed we took it all to our 5er storage and hooked up. Once we had done a quick tug test, we put the 5er weight fully on the truck and checked the measurements again and did a check on level so we could be sure we weren't nose down/up.
Worth the time to do the math and measurements for sure. Gives peace of mind.
coderider is offline   Reply With Quote
Old 03-18-2013, 07:55 PM   #14
Denver, CO
garbonz's Avatar
I just hooker er up and took off, didn't know I should be so worried.
2017 Fuse 23T
Old 03-18-2013, 07:58 PM   #15
Fulltime family RVer
X2- except I knew better, just didn't know how.
ependydad is online now   Reply With Quote
Old 03-18-2013, 08:10 PM   #16
coderider's Avatar
Just a thought, you could do a google on the model of your hitch and I am very sure you can find a PDF of the manuals that should/probably have the installation instructions for your hitch. Then you could check the measurements yourself and be positive.
Old 03-18-2013, 08:32 PM   #17
OL Creeker's Avatar
Odd stuff
Originally Posted by EXGMTech View Post
Looking at the height of my new hitch I'm thinking it's going to be too high for our new 5er picking up on Thurs...I have one more hole of adjustment that will bring it down 1 more inch, but still looks too high. Or am I wrong? Never owned a 5er before...when I looked at the pin height this wknd after signing the paperwork it looked way lower than my hitch head.
We're getting a '13 Crusader 335BHS.
What the heck is all that white stuff on the house roof and next to the truck?
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 03-18-2013, 08:46 PM   #18
Denver, CO
garbonz's Avatar
My superglide is not adjustable. So I don't worry.
2017 Fuse 23T
Old 03-18-2013, 08:51 PM   #19
Toy-aholic
that there white stuff is what we were blessed with for our hour's ride taking the trade to the dlr....glad I wasn't bringing the new one back yet....the very thought of all that salt all over our new baby!!!!
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 03-18-2013, 09:06 PM   #20
OL Creeker's Avatar
5er hitches
We're doing lots of research before buying our first 5er. Same goes for the hitch. After much reading and talking with RV'ers at several campgrounds, I've decided upon the Pull Rite Super Glide. Yes, it's a bit pricey. But we're concerned with safety and the ease of parking as well.
Duramax/Allison
