Old 05-28-2016, 10:48 AM   #1
5th wheel hitch selection
Hello,
DW and I are looking a 5th wheels and I am looking for information on hitches and pin boxes. Is there a primer out there for newbies? What needs to be considered? What about the height?
I am considering a B&W Companion hitch as I like the concept of removing and having a flat bed.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 05-28-2016, 10:52 AM   #2
jtstromsburg's Avatar
Not sure of a great place to read other than a search on this forum but I will say I live our companion hitch by B&W and it saved our truck in a potential roll over accident two years back. Wouldn't own a different one after that. Easy to trust the latch mechanism and, like you said, easy to remove for an clean bed with no rails sticking up.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-28-2016, 11:03 AM   #3
Jerry01's Avatar
We have a B&W as well and love it. Very well built. I have never owned another but I helped a buddy hitch his up and he has a Reese. The jaws are 1/2 as thick and I didn't care for the locking mechanism. We will stick with our B&W. Jerry
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 05-28-2016, 11:34 AM   #4
Have had a superglide, a curt and now have B&W. Like the B& W best.
TXCPL is offline   Reply With Quote
Old 05-28-2016, 12:55 PM   #5
I have a B&W and love it, I didn't have it hooked up quite right, it's got a pin under the body that you can pull and I left it loose for over 2,000 miles and never had a problem. It's got a bolt on the hitch that has to be tightened up and I didn't. It's got bolts on the hitch and they all have be tight, well the idiot that installed it told me wrong. But the hitch work great and it works great now hitched up right. I also have a bed saver on the hitch. In my opinion you can't go wrong with a B&W Companion
spock123 is offline   Reply With Quote
Old 05-28-2016, 01:06 PM   #6
Torch's Avatar
I have a 2013 Ram 2500 crew SB, I had a B&W Companion slider which I liked but it was just a pain to get it out of the truck so I went with an Andersen Ultimate goose neck , it weighs 70 lbs, it's offset a tad so I don't need the slider. I used it for the first time last week and found it shuddered less than the B&W. It was easy to hitch up and so far so good. It uses the same base as the B&W Companion used(B&W).
Torch is offline   Reply With Quote
Old 05-28-2016, 01:59 PM   #7
To get the hitch out of the truck bed, this is what I do. I lock the lock with a lock so that no one can pull the pin on the hitch. With hitch locked up to pin I unfasten the hitch from the truck and then I pick up landing jacks on camper and I drive off. The pin box will hold that hitch. My camper weighs 13,000lbs I figure it can hold a hitchj
Old 05-28-2016, 02:35 PM   #8
Kenny kustom's Avatar
Did the same thing last weekend.
Needed the empty bed of the truck.
Works slick as....
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-28-2016, 02:53 PM   #9
BandJCarm's Avatar
Well I never.........
I'd have been 200 years old before it hit me to do that.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-28-2016, 03:19 PM   #10
Jim34RL's Avatar
I use a hoist that I hang from the garage support beam. I raise the hitch in the air and pull the truck out, I reverse the procedure when I want to reinstall the hitch. The hitch is stored on a roll around support when not need, in the garage. Takes about ten minutes to uninstall and reinstall, this way the bed is empty when I am not pulling the 5er.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
5th wheel, hitch, select, wheel
