Old 11-24-2016, 10:49 PM   #1
5th wheel hookup
We have just got a Flagstaff Ultra Lite 5th Wheel with a Reese 16k hitch in the truck. May problem is when I go to hook up. If I'm not exactly right it will hang on a little lip and will not lock. So times it can take up to 15 minutes to hook up.
Jerrymac is offline   Reply With Quote
Old 11-24-2016, 11:22 PM   #2
NMWildcat's Avatar
Not sure what lip you are talking about. Are you talking about height or having to be straight on that you have to get just right? Try the teflon lube ring that fits around the kingpin, it helps the hitch to slide over the plate. Also play with height. Every 5ver we have had has its own 'trick' for easy hookup. Usually height. Practice makes perfect! Good luck!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 11-24-2016, 11:44 PM   #3
Usually takes me one try and maybe 5 minutes to be ready to pull out. I used to use a teflon lube plate, but found issies with them, so went back to grease. First, line yourself up with the hitch pin and while sitting in the drivers seat have an assistant marka spot you can easily see in the mirror. Makes a nice simple permanent line up. Height is the only other thing you need to worry about. Get hitched, then pull out and take a measurement from the ground to the bottom of the fiver. Then its a simple matter of setting trailer nose height to match your measurement and back in. Heck a simple dowell rod cut to the proper length will make measureing a snap.
donniedu is offline   Reply With Quote
Old 11-25-2016, 12:47 AM   #4
CaptnJohn's Avatar
I use the plastic disk as it eliminates the mess of grease, but either work well. The dowel rod to measure may work for you. I simply eyeball about 1/2" high when unhooking and 1/2" low when hooking so she rides up and in. I know the auto-level will put it where it was released from but have not used that feature -- yet.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 11-25-2016, 01:01 AM   #5
Islander's Avatar
Along the same idea that 'donniedu' mentioned is what I do....
If I should have any pressure on the 5th wheel 'pin' while hitched it can make it difficult to un-hitch until the pressure is eased off the pin.
Sometimes this may take a few minutes to find the a balance of no pin pressure (so to speak) until I can pull the leaver to un-hitch.
Here is what I do to make hitching up easier...
Tools needed : tape measure, pencil & paper, stored in the forward compartment.
- right after unhitching and moving the truck forward out of the way
- before you raise or lower the rig to level it out
- measure from the ground to the bottom of the pin
- record this measurement.
- when it's time to reconnect just raise or lower the pin to the
'measurement'...back up the truck and listen for the "click".
I am able to just see the "top" of the 5th wheel hitch in the back of my truck, mainly because of the packer storage box is in the way in the bed.
I marked both the Pinbox and 5th wheel hitch with red reflective tape.
On the 5th wheel hitch I place a Red Arrow ,pointing up, of the reflective tape 'at center / on the front edge of the hitch'
On the Pinbox I placed a Red Arrow , pointing down, of the reflective tape 'at center / on the front edge of the Pinbox'.
In my case, I can easily see both of these Red Tape Markers in my rearview mirror and knowing that I have returned the hitch pin to the same position in height, to where I un-hooked, I have confidence that I will have a smooth hook-up.
If the 'tape idea' will not work in your case there is always other methods, like magnetic flag markers etc. .
I hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 11-25-2016, 06:23 AM   #6
tom39's Avatar
Jerry, I too recently traded in my TT for a 5th wheel (Sept '16) and I found that even though hooking up is easier, when you are new to 5th wheels, having the kingpin at the correct height seemed to be a lot of trial and error. Also from experience, having my wife's help wasn't the solution either, unless I wanted to wait for her bathroom break, be on standby while she attended to the dogs or hear "oh sorry I wasn't looking, go ahead I am ready now. Don't worry you didn't hit it."
Anyway, I was at the Hershey PA show this year and seen this leveler gadget called Revoleveler. And after a crazy amount of research, I broke down and bought one. There are very few products that I would endorse but this thing is AWESOME!
It is so easy to use, to hook up you set it in the nest and press 4 buttons and it will tell you exactly how high you need to raise your landing gear no matter how your 5th wheel is parked. When you are at your site, with the press of a few buttons it will tell you exactly how high you need to be to unhook, level front to back, level left to right and when you are ready to go home, again a press 4 buttons extend your landing gear until the lights turn green and you are ready to back into place.
This thing is so good that when I level my 5th wheel I have the Revoleveler set to list my 5th wheel 1/2" to the left so that my bedroom door stays open and the majority of water from rain and the ac unit drain to the left side.
It is pricey though and is around $140 but IMO worth every penny. Once set, you will never have to look at a bubble level, pull a tape measure, guess how many blocks you need, depend on someone else to watch a bubble to tell you that you're level or guess where you need to be.
I have added a link to their website if you want to check it out.
ReVo Leveler
Hope it helps,
Tom G
2011 Rockwood 8288 SS UL
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
tom39 is offline   Reply With Quote
Old 11-25-2016, 06:54 AM   #7
A simple and easy way to determine the correct height of the 5'er needed for hooking up is:
1. Unhook trailer
2. Look at emergency breakaway cable as it is hanging down. Determine how far it is off the ground.
3. Use a few links of inexpensive chain and add these to the cable until the chain links touch the ground.
This method will consistently reproduce the correct height on level ground. It is also a great start for hooking up on unlevel ground.
TXCPL is offline   Reply With Quote
Old 11-25-2016, 07:37 AM   #8
BandJCarm's Avatar
1. Unhook trailer
Where's the LIKE button?
And where will you be next spring when I hook up next and remember that this post mentioned something about how to fix the hookup issue but not the specifics???
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 11-25-2016, 08:21 AM   #9
Hi,
I've used a variant on TXCPL's method for years -- just tie the proper length of string to the hanging loop once and you're done.
Simple, effective, snd cheap.
FWIW.
Rich phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 11-25-2016, 08:41 AM   #10
Ford Idaho's Avatar
I stand next to the lite with my left shoulder under the nose and my left fore finger on the switch, when I can stand straight up I can hook the 350 up easy.
5th wheel, wheel
