03-11-2017, 10:42 AM
#61
Originally Posted by CaptnJohn
I little off topic but ~~~ decided to buy a 5th wheel tailgate for my new truck. Many are out of composite but not real strong. I bought the Husky made from aluminum, pricy but very happy with it. No need to drop the gate or get in/out when hitching.
The point ~~ it took 2 of us to get the F350 gate off as it is a tad heave for one. The 5er gate is extremely light. I could not find the weight of the F350 gate with camera and step but it is at least 5X the weight of the 5er gate. Makes life easier too.
No way would I give up my camera and old man step for a 5th wheel tailgate
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-11-2017, 10:45 AM
#62
I wish I had the old man step. I almost need a ladder to get into my Ram.
03-11-2017, 10:52 AM
#63
Easy peasy. This is better......contacts the ground and is more stable.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
FROG AR-0019-242
03-11-2017, 10:53 AM
#64
You still have the 'beeper' when backing and can install a camera for $40 or ready made for $90. I'm 69 and do not miss the step. I keep a boat hook in the bed and in the 5er which keeps me from having any need to get in the bed or the pass thru storage.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-11-2017, 10:57 AM
#65
You must be tall, or your truck must be short. Or both. I can't reach the pin to latch or unlatch the hitch without a step stool.
FROG AR-0019-242
03-11-2017, 11:15 AM
#66
Blog: RVroadtripper.com
Lots of changes the dealer or owner can make. Tailgate change, airbags, side steps, grill guard, big or heavier wheel upgrade, goose hitch plus Andersen OR B&W companion 5er hitch, etc. Some add, some takeaway. All those happen after the sticker was created. The 2500 GVWR is 10000#. After all the mods, drive over to CAT scale, fill up with fuel and get a weigh ticket. 10000 minus the the Trucks total weight is your 'Revised' sticker payload.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
03-11-2017, 05:41 PM
#67
I keep the boat hook to reach things EXCEPT the lock on my hitch. Pulling the step out or crawling under the 5er is crazy compared to the folding step stool that stays in the truck. The folder takes very little space, is cheap, and makes reaching the lock easy. A 2016 F350 4X4 is not short. Still wondering how you use the step with the 5er nose over the bed.....
03-11-2017, 05:42 PM
#68
I may be fat, but I make up for it by being really short.
FROG AR-0019-242
03-12-2017, 08:08 AM
#69
I did it for 4 years with a 2012 Tundra Crew max with no issues. Towed it thousands of miles. I have a Reese Revolution on my 5W and put E-rated ties, rear sway bar and Timbrins. I did recently move up to a diesel, I do plan on moving up to a bigger 5W soon. What I am looking at the Tundra could not handle. If Toyota ever makes a HD Diesel, I will be back. Those trucks are bullet proof.
2018 Jayco Eagle 355MBQS, Andersen Ultimate Hitch
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
03-12-2017, 03:03 PM
#70
I'm a big fan of this camera. Easy to install and doesn't block any part of the plate like cheaper units.
www.amazon.com/Boyo-VTL375-Ultra-License-Camera/dp/B002X8VF4C
03-12-2017, 03:33 PM
#71
Originally Posted by DavidBo
does this work with the factory screen or require another screen? Having the 7 inch screen on my dash with the lines that move with the steering wheel is pretty awesome though. Anything else would be a down grade. Good option for someone installing one that doesn't have a factory camera though.
03-12-2017, 04:43 PM
#72
I'm sure that varies vehicle to vehicle, depends on what kind of video input your truck's headunit has. This camera uses a standard RCA plug for video and gets power from the vehicle's backup lights. You might need an electronic specialist to patch it into some factory systems.
