Old 02-03-2013, 07:40 AM   #11
Camper Less Camping
Cajun Po-Boy's Avatar
Originally Posted by ttrost65 View Post
I'm curious, how does one actually drop a a fifth wheel? Is it user error or a mechanical failure? With the hitch I have now(draw bar), it's possible to drop a fifth, it's either closed or open. There is no mistaking it. I'm upgrading hitch, but is there that much uncertainty of whether the hitch is closed or not, that you have to add additional equipment for safety?
Good question...no uncertainty with my PullRite!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-03-2013, 07:59 AM   #12
I'm curious, how does one actually drop a a fifth wheel? Is it user error or a mechanical failure? With the hitch I have now(draw bar), it's impossible to drop a fifth, it's either closed or open. There is no mistaking it.
Same here.
And I have to wonder, if a hitch is so unreliable that one has to install such a backup, why not just buy a better hitch?
I never give ours a second thought.
bakken is offline   Reply With Quote
Old 02-03-2013, 08:02 AM   #13
It is just a safety thing a just in case type of thing. A lot cheaper then what it cost to repair your 5ver and tow vehicle.
RickV is offline   Reply With Quote
Old 02-03-2013, 08:33 AM   #14
AquaMan's Avatar
I understand concept, but still wonder if its a user error or a malfunction of a jaw type hitch. There is no doubt in a draw bar hitch being fully engaged. But there is play in the hitch, and is the reason for my upgrade. I just want to know if there is a mechanical flaw inherent with these hitches or if its a human error problem. If its human error in not checking whether hitch is locked, how would you remember to close a bar on a safety device? If its a design flaw, maybe I should engineer a new hitch.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 02-03-2013, 08:46 AM   #15
jevanb's Avatar
I have never dropped one but post who has and you would be surprised
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-03-2013, 09:01 AM   #16
What brand of hitch do you have?
We have the drawbar type, and it is very tight, no play whatsoever.
Old 02-03-2013, 09:03 AM   #17
Fulltime family RVer
It's my understanding that MOST dropped hitches are from user error. The 2 biggest reasons that I've read about are:
A) High-hitching where the pin ends up being too high. The latch closes, but the pin isn't really grabbed. I think this is more prevalent on some hitch types than others (e.g. draw bars).
B) A break down in process (e.g. missing a step or doing things out of order) - missing a step like forgetting to latch the arm. Or doing things out of order - like unhitching before lowering the landing gear.
That all said- (I've never used these devices) I personally don't like what I have read and imagined to Butch's hitch saver device - my problem is generally that I sometimes turn into a space cadet (I moved the fiver with my between-the-wheel chocks still in place once). I don't like that I actually have to do something with Butch's hitch saver. I want it to always be engaged in case I fluck up.
It's my understanding that the Blue Ox Bedsaver is just that- it's always engaged and only catches the pin if you drop that FW. Though, I think it's close to $300 vs. Butch's bed saver which is way less.
Just my $0.02 from reading forums.
Doug
ependydad is online now   Reply With Quote
Old 02-03-2013, 09:16 AM   #18
Doug
On the draw bar type hitch, it will not close unless the pin is in the proper spot.
Old 02-03-2013, 09:20 AM   #19
Then my assumption appears flawed. :-) I understand the concept behind high-hitching, but it seems that everyone considers their hitch "high-hitch proof". I know I can't imagine how it's possible with my B&W and it's jaws.
Old 02-03-2013, 09:23 AM   #20
B47
Originally Posted by NevadaM View Post
B47, Not sure of the exact model, it's a Husky 16k easy glide (rolls back about 11"). I went to Butch's site and found one under 'other hitches' that looked the same except for the roll feature. When the latch came, it fit perfectly and installed in minutes. It's another step to add to the hook-up procedure, but likely worth it. With a new trailer and all, I'm tempted to put together a check list.
Nev
Thanks - I have a Husky 16 ks and his site doesn't really show a picture of the kit installed on that model. It does say the kit can be installed on the Husky. Guess i will call him.
Does the kit come with the required drill bit?
5th wheel
