07-14-2012, 07:53 PM
Brigitte
5th wheel level while driving
How level front to back should the 5th wheel be when hitched to the truck?
Just weight it and 20% on hitch which is good but I had to load mostly in the back to keep the weight off the hitch. The fifth wheel sits lower on the back than the front.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
07-14-2012, 09:11 PM
Have you pulled it like this yet? How did it pull before you move the stuff? Was your truck overloaded before? If it tows ok now like this then do you have any room to lower the hitch in the truck bed?
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
07-14-2012, 09:42 PM
Level front to back is always best. How far out of level is it? If it's less than 2" front to back, probably not a big deal. I'd still try to level it if you have adequate clearance above the truck's bed rails. You only have to lower the hitch (or raise the pinbox) half the difference that you've measured.
Dave
07-15-2012, 04:57 AM
Brigitte
Have to measure it, cannot remember exactly but I think it's near 2"
Towed very nice, no chucking, sitting normal in the truck. 1.5" sag with timbrens.
My guess is we changed tires from P275/60R20 to LT 275/65R20 (you know those darn 20's) so truck sitting a little higher than when the hitch got installed.
Superglide 2700
Timbrens
07-15-2012, 04:59 AM
Brigitte
6" between bed rails and 5W
Superglide 2700
Timbrens
07-15-2012, 09:45 AM
You could drop your hitch 1 hole. Just watch the uneven ground. Mine has 5" and I have never come close to hitting.
2006 EZ GO 6" lift
07-31-2012, 11:05 AM
Brigitte
Had the rig in for adjustment and tech said no room to adjust unless we cut into the front nose cap (not going to happen). Truck is 4x4
Superglide 2700
Timbrens
07-31-2012, 11:58 AM
??? To gain clearance over the bed rails? Are you trying to drop the hitch to make the camper more level?
You said the truck's rear only drops 1.5"...is it level? If you were to increase the gap on the timbrens and allow the truck to settle more, it would drop the nose of the camper down.
How far out of level is the camper?
Dave
07-31-2012, 02:05 PM
Had to raise the camper. No adjustment on pin box to have needed bed rail clearance. Dealer had a square tubing welded under camper frame and then attached spring shackles under that tubing. Camper is close to level and I can get up drive without back end of camper dragging. Works great. Ok on overall height 12'6"
07-31-2012, 02:43 PM
Brigitte
Camper is 4 inches higher behind landing jacks than at back
Almost 6 inches between camper and rails
Truck is nice and level now and that is a great suggestion but I've the 275/65R20 and I'd like to keep the 4.5 inch space i've got now between tire and wheel well ...
4 inches
Truck is 4X4
Pretty disappointed with the choice i made when getting that truck, probably will trade up in a year or two to a 3/4 ton or 1 ton and not 4x4 which makes truck too high
Dave
If no solution, should I worry?
Superglide 2700
Timbrens
07-31-2012, 02:45 PM
Brigitte
4 inches
Truck is 4X4
Dave
Superglide 2700
Timbrens
07-31-2012, 05:40 PM
A 4" difference from front to back is a fair amount. Even if you could drop the front an inch for a 2" difference overall, it would be much better.
The only other option is to raise the camper 2" using spacer blocks at the leaf spring mounting points as mentioned earlier.
Dave
07-31-2012, 08:38 PM
Brigitte
Thanks Dave, I'll see if I can get a spacer put in the back.
I appreciate the help . Wish the RV techs cared half as much.
Superglide 2700
Timbrens
08-02-2012, 06:52 AM
Your post made me look at my set up again. Thank you. My super springs brings up the back of the truck by 2 inches. When I hook up, the trailer brings the truck down 1 1/2 inches. I have 6 inches from rails to bottom of trailer. and my trailer is the same hight off the ground front and back. Would have never really thought all about this till your post. I hope things are going well and the kinks getting worked out. Be safe and great summer.
Mike - Ottawa
'10 Rockwood 8280ws
2014 Ram 2500 SLT HD Crew Cab 4X4 3.73
08-02-2012, 07:04 AM
Brigitte
I obviously worry way too much and over analyze things
Superglide 2700
Timbrens
08-02-2012, 08:04 AM
Well, that is far better than not worrying at all, like far too many seem to do!
