Here is a list of payloads that are found on the yellow sticker on the door jam.
It’s 5th grade math and not some sort of rocket science to staying within your truck specs. These figures are with one
200 lbs driver and 250 lbs hitch with a 5er loaded ready to go camping.
The numbers below came from Tow Planner -
Towing Calculator based on Truck's Payload/CCC - Towing Planner
Payload = 1200
You're adding approximately 450 lbs. to the truck. You have 750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,000 - 3,750 lbs.
Payload = 1400
You're adding approximately 450 lbs. to the truck. You have 950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,800 - 4,750 lbs.
Payload = 1600
You're adding approximately 450 lbs. to the truck. You have 1,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 4,600 - 5,750 lbs.
Payload = 1800
You're adding approximately 450 lbs. to the truck. You have 1,350 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 5,400 - 6,750 lbs.
Payload = 2000
ou're adding approximately 450 lbs. to the truck. You have 1,550 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 6,200 - 7,750 lbs.
Payload = 2200
You're adding approximately 450 lbs. to the truck. You have 1,750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,000 - 8,750 lbs.
Payload 2400
You're adding approximately 450 lbs. to the truck. You have 1,950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,800 - 9,750 lbs.
Payload 2600
You're adding approximately 450 lbs. to the truck. You have 2,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 8,600 - 10,750 lbs.
