Old 04-11-2016, 09:53 AM   #31
Fulltime family RVer
And, another 1/2-ton thread that's completely derailed. Pictures, people- pictures!
ependydad is online now   Reply With Quote
Old 04-11-2016, 10:10 AM   #32
leefl's Avatar
Well, I'm now towing with an F250, but I very briefly had an F150 eb supercrew, but realized (thankfully before installing hitch) that the advertised payload capacity, and the payload capacity on the door-jam are very very different.
I'm sure it could have pulled the weight, but I was certainly not comfortable being substantially over payload capacity (my "ultralite" 5er has an 1800lb pin weight), so I returned the F150 within the week, and bought the F250.
(Tho' I'm now wanting one of the 2017 F350's, with all the gadgetry from the 2015/2016 F150s and more )
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-11-2016, 10:34 AM   #33
Blackrock's Avatar
We were doing OK until the feller with the full pull F350 started in.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is online now   Reply With Quote
Old 04-11-2016, 12:00 PM   #34
Canadian Member
itat's Avatar
If you understand 1/2 tons you'll know that the payload is the weakest spec. The tow rating is rarely the issue. Apparently a 1/2 ton Tundra can pull the space shuttle with no weight on the tongue.
If you have a payload capacity of 1900# and you put a pin wt. of 1700# on it, you'll almost certainly exceed the specs when you and any passengers get into the truck. That doesn't mean it can't handle it, just as long as you are aware of it and comfortable with it.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-11-2016, 12:29 PM   #35
RetiredRVer
Originally Posted by itat View Post
I don't think anyone on this thread is suggesting a F350 or 3500 isn't a better tow vehicle. That's a no brainer.
I towed my Heritage Glen 282RK (7500# loaded for camping) for two years with a 2010 Ram CC 4X4, 5.7 Hemi with a 3:55 axle. It had a towing capacity of 8400 pounds, (according to Ram) and a payload of 1900 pounds, neither of which I exceeded. However, I was constantly watching the temps. of both engine oil, and transmission oil. I had a hard time keeping both under 200 degrees....especially the trans. It was okay on flat land, but any long grades I had to either slow down (from 60 MPH), or shift to a lower gear to reduce trans temps. I finally got tired of constant worry of breaking something, and purchased a 2015 Chevy 2500HD 6.0 gasser w/4:10 axle. Trans temps never exceed 190 degrees, even pulling the TT thru the Rockies. Sometimes Peace of mind is worth the extra cost. It pulls better, stops better, and handles much better then the 1/2 ton. Just wanted to let everyone know why I upgraded to a bigger TV. Thanks for listening, and happy camping!
checkmate99 is offline   Reply With Quote
Old 04-12-2016, 02:09 AM   #36
You said it before I could, those were almost facts weren't they??? Pulls better, better fuel mileage, can't feel it, and on and on
jerky is offline   Reply With Quote
Old 04-12-2016, 02:30 AM   #37
Just a member
kandl's Avatar
Yep, a little extra gearing (3:92) can go a long way when traversing them pointy hills. We've lugged the 7500 lb Rockwood back and forth across the Rockies on numerous occasions over the past five yrs and the little Ram has consistently performed like that proverbial Little Engine that Could. Seen tranny and engine oil temps well in excess of 200 degrees but thus far she's none the worse for wear. We do ponder about bigger and better TVs but hard to rationalize when the old gal just doesn't want to quit.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 04-12-2016, 07:25 PM   #38
Blackrock's Avatar
Welp fellers. I'll be telling you all about it come this weekend. I made a deal this week on a light 5th wheel. Went outside the FR family and got a Keystone Laredo 265SRK. Specs out at 7260 dry weight and 1480 pin weight. Already installed the air bags in the coil springs and going to have slider hitch installed this week and pick the rig up Friday in Tucson.
Old 04-12-2016, 07:46 PM   #39
Cyber Phrenologist
Radio's Avatar
OK... here's the pic the OP asked for...
Way upgraded tranny cooling capacity
Michelin 245/70 R 17 load range E tires
Timbrens
It works on my budget. The loaded trailer weighs 7800, truck is rated 8600. Pin is about 900. And the tv is paid for.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 04-12-2016, 08:15 PM   #40
Evidently some folks can't comprehend PICTURES ONLY of 1/2 Tons pulling 5ers.
5th wheel, wheel, led, pictures
