Old 05-26-2016, 08:08 PM   #41
The tow police can't help it. It's in there blood to be wrong on things.
porkchopjack is offline   Reply With Quote
Old 05-26-2016, 08:15 PM   #42
CWSWine's Avatar
Here is a list of payloads that are found on the yellow sticker on the door jam. Itís 5th grade math and not some sort of rocket science to staying within your truck specs. These figures are with one 200 lbs driver and 250 lbs hitch with a 5er loaded ready to go camping.
The numbers below came from Tow Planner - Towing Calculator based on Truck's Payload/CCC - Towing Planner
Payload = 1200
You're adding approximately 450 lbs. to the truck. You have 750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,000 - 3,750 lbs.
Payload = 1400
You're adding approximately 450 lbs. to the truck. You have 950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 3,800 - 4,750 lbs.
Payload = 1600
You're adding approximately 450 lbs. to the truck. You have 1,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 4,600 - 5,750 lbs.
Payload = 1800
You're adding approximately 450 lbs. to the truck. You have 1,350 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 5,400 - 6,750 lbs.
Payload = 2000
ou're adding approximately 450 lbs. to the truck. You have 1,550 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 6,200 - 7,750 lbs.
Payload = 2200
You're adding approximately 450 lbs. to the truck. You have 1,750 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,000 - 8,750 lbs.
Payload 2400
You're adding approximately 450 lbs. to the truck. You have 1,950 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 7,800 - 9,750 lbs.
Payload 2600
You're adding approximately 450 lbs. to the truck. You have 2,150 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 8,600 - 10,750 lbs.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-27-2016, 08:19 AM   #43
Refreshing RVs
you sure spend a lot of money on RVs- how does that work for you? Is it anywhere near profitable to do that. And I think you swapped out a F250 for a F350 also. Let me in on your secrete if you have one because I would like to do the some of the same things.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 05-27-2016, 09:06 AM   #44
Mr. Dan's Avatar
I'm sorry... but to whom are you addressing this post?
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-27-2016, 09:33 AM   #45
(Dry Huunday)
DreiHunde's Avatar
...of Half tons towing fifth wheels!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is online now   Reply With Quote
Old 05-30-2016, 09:31 PM   #46
Blackrock's Avatar
Ain't she pretty
Sitting at Gold Springs near Milk River AB.
Name:	Gold Springs Canada.jpg
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is online now   Reply With Quote
5th wheel, wheel, led, pictures
