Old 10-08-2015, 12:10 PM   #21
Jack350's Avatar
I would advise looking into the Andersen aluminum hitch. At 32 pounds and huge towing capacities I have been very happy with this hitch. I have a 8 foot box, but the hitch does move the pin back at least 5 inches which might help shorter trucks. There is little if any chucking and the hitch feels great when towing. When you are done towing, just remove and hang on the wall next to the truck which takes all of about 3 minutes. This is a great hitch with no binding from side to side and there is no down side as far as I can tell after one season of towing with it.
2012 Crusader 26RLD, 2017 F-350 4X4 6.7.
Hayes Autoformer, Correct track, Maxxis 8008E, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 10-08-2015, 06:31 PM   #22
Busybeavers's Avatar
Wow, thank you all for your input! That is a lot of information that really helps. I see that I will need a set of scales right away to see what it actually really is doing. I have never trusted the information you see advertised and most time the trailer sticker for dry weight is totally wrong. But is does tell me to do a little more research before I make the final decision. I really do like these forums, you get input from all kinds of different setups. Keep up the get info, Happy Camping!
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 10-08-2015, 10:52 PM   #23
amblt's Avatar
I've been advised to consider adding leaves to my springs instead of air lifters, on the premise that springs are much less likely to fail and leave you up the creek.
amblt is offline   Reply With Quote
Old 10-09-2015, 07:34 AM   #24
jeff64's Avatar
My buddy is running something similar to you with the shorbed. Be cautious of when you jacknife the thing, he broke out the rear window in the TV. Bummer!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
500, 5th wheel, wheel
