Old 03-10-2015, 01:30 PM   #1
5th wheel to box clearance
How much clearance do you guys run and not have problems? I have a 2008 chevy 2500hd and 2015 sierra 380bh5 with rotoflex pin box. B&w companion hitch adjusted all the way up, 1 set of holes for pin box to come down yet and i have approx 4" clearance when hooked up
Sent from my SM-N910V
mustardbucket107 is offline   Reply With Quote
Old 03-10-2015, 01:32 PM   #2
Jim34RL's Avatar
I try to have at least 6" of clearance.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 03-10-2015, 01:36 PM   #3
Jim is right. 6" is ideal. 5" minimum. Over 6" ok too...
taken is offline   Reply With Quote
Old 03-10-2015, 02:28 PM   #4
Has anyone else recognized the chevy box sides are ridiculously high compared to other makes?
Old 03-10-2015, 02:30 PM   #5
And if i move my king pin down do the last bolt hole, anybody know the torque spec
Old 03-10-2015, 02:38 PM   #6
John McClain's Avatar
I have 6 1/2 you can look up torque specs. for bolt size online
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 03-10-2015, 02:46 PM   #7
Rodney & Patty
As for my experiences with box clearance - I really wanted to try and keep my fifth wheel 4-5 inches above the box since that's where the trailer looked the most level. The first time I backed into a less than perfect site I scarred my box rail and the underneath of the 5th wheel nose. Since I have been running 6" without issue.
rdenslow is offline   Reply With Quote
Old 03-10-2015, 02:50 PM   #8
Back to Shasta Camping...
As I recall the torque spec for my 5th wheel hitch was 90 ftlbs... that was for head bolts to side stanchions....
Hitch is a Curt Q20...
His TV: 2014 RAM 3500 MC DRW 6.7 CTD AISIN
His RV: 2014 REDWOOD 38FL (House)
Her TV: 2013 RAM 1500 CC 5.7 Hemi
Her RV: 2010 VCross 20VFB (Camper)
Bill n Diana is offline   Reply With Quote
Old 03-10-2015, 06:59 PM   #9
davel1971's Avatar
all the brands have deeper pickup boxes than they used too. Good for everything EXCEPT 5th wheel towing.
David & Lynn
Old 03-10-2015, 07:23 PM   #10
trbomax's Avatar
When the dealer switched out my pin box they used new bolts/star type washers and nuts. I questioned that and was told that the bolts were "stretch stressed" ? in other words,they are only to be used once and then tossed because they are now "stretched". This was in acordance with the lippertt/FR warranty.They torqued the new ones to 110 ft lbs.
edit) they also tightened and torqued them in a cross pattern,much like you would with a cylinder head or wheel. They started at 60, then 80,90, and 110.
trbomax is offline   Reply With Quote
Old 03-10-2015, 07:51 PM   #11
Crusadernoob's Avatar
You need to see what size bolts you have on it, when I changed mine the torque was 210ft. Lbs just google torque spec and go with that. It is also different torque dry vs lubed threads.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 03-11-2015, 07:25 AM   #12
MtnGuy's Avatar
And reaching over the sides to get something out of the bed.
Old 03-11-2015, 11:37 AM   #13
MTN GUY, I installed folding side steps under the bed just behind the cab. on my 3500HD. They work great.
grayfox is offline   Reply With Quote
Old 03-11-2015, 06:27 PM   #14
I found a single step Werner brand step in the ladder dept. at Lowes for $14.00, perfect for the F250 FX4, have no problem reaching the handle on my B&W.
NACE is offline   Reply With Quote
5th wheel, wheel
