Old 08-30-2013, 11:21 AM   #31
Still would appreciate the type of F150 (cabtype, WB, axle ratio, engine) that has over 3000 lbs payload. The online configuration tool on ford.com never gave me those numbers which would convince me. 2200 lbs max the max?
Flying dutchman is offline   Reply With Quote
Old 08-30-2013, 11:25 AM   #32
Regular cab 4X2 145" wheelbase with 5.0 liter...3120 lbs..
2013 Ford F-150 | View Payload Specifications | Ford.ca
_______________________________________________
Tim & Jenn
2009 Forest River Grey Wolf 235 5er
2003 F-350 Superduty 6.0 l Diesel
DSP 17K
aiscpl6 is offline   Reply With Quote
Old 08-30-2013, 11:27 AM   #33
with Heavy Duty Payload Package of course...:-)
Tim & Jenn
DSP 17K
Old 08-30-2013, 11:45 AM   #34
Fulltime family RVer
Agreed. And I'm still floored... I never would have guessed!
ependydad is online now   Reply With Quote
Old 08-30-2013, 11:52 AM   #35
The other factor to consider is the curb weights, a F150 is approx 4700 lbs with a max payload of 3120 lbs whereas a F250 is approx 6600 lbs. with a max payload of 3700 lbs. IMO having the extra 2000 or so lbs makes a big difference when the trailer is going over some rough spots and seems to have a mind of its own sometimes...
Tim & Jenn
DSP 17K
Old 08-30-2013, 12:34 PM   #36
avolnek's Avatar
This is a really good point.
This is the main factor I would advise not pulling a 5er or heavy TT with a half ton. When the trailer is steering the truck due to the lack of weight on the TV side of the equation things can get scary really fast...
My previous trailer, grey wolf 26dbh was a great fit for my 1500 hemi. I could pull it with ease through hills and had no complaints what so ever. When I switched to the 2500 cummins man was it nice! I felt so much more in control of the trailer! My only complaint now is that the fuel tank lasts longer than my pee tank does and I am stopping at rest stops to relieve myself between fill ups!
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-30-2013, 02:16 PM   #37
I had an experience driving on a 4 lane highway that I expected to be fairly smooth but as it turns out there was a few miles where the road could of been used for Olympic Mogul skiing and I was happy to have the extra weight.
lol....I hear that, 160 liters of diesel lasts a longggg time...
Tim & Jenn
DSP 17K
Old 08-30-2013, 03:33 PM   #38
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
By payload does that mean the same as GVAW? (Gross Vehicle Axel Weight) It's the GVAW that you really need to look at. The actual weight will be calculated by weighing the truck and knowing what the weight is on the rear axle. The truck should be fully loaded with a full tank of gas. Add this to the estimated weight of the hitch. Add this to the pin weight of the trailer. This is the number that must not exceed the GVAW. As I posted earlier, this is the number that drove my nuts and limited the number of RV's I could consider for purchase without exceeding limits. The maximum pin weight I could have was around 1200 pounds. That's why I bought a F250 which really opened up the variety of RV's that I considered for my first 5W.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 08-30-2013, 03:41 PM   #39
Well, essentially payload is the difference between the GVWR (Gross Vehicle Weight Rating...max your truck can weigh) minus what the truck weighs empty but yes you don't want to exceed what the rear axle is rated for. When gauging the actual max pin weight for a fifth wheel you have to take into account everything in the truck, so payload minus passengers, luggage, beer, etc...whatever is left is your max pin weight...
Tim & Jenn
DSP 17K
Old 08-30-2013, 03:44 PM   #40
And don't forget the weight of the 5er hitch, which is not insignificant.
5th wheel, wheel, truck
