Old 06-23-2015, 12:02 PM   #11
I have a slider in my Ram and have never used it. If I ever replace it , I will get the companion. Several of my fellow campers use it in their short bed trucks with no issues.
TonyH is offline   Reply With Quote
Old 06-23-2015, 12:04 PM   #12
Phat Phrog Stunt Crew
elind's Avatar
I have a GMC 2500 CC 6' 6" box and a Wildcat 327 ck without a slider hitch. Only once did I have an issue and that was when I was making a turn pulling out of a driveway going up hill. The corner of the FW touched the front rail of the box.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 06-23-2015, 12:12 PM   #13
mike2wheels's Avatar
I have a Reese 16k slider, but have yet to use the slide function except to test it. With the sculpted nose of the Silverback I can turn greater than 90 degrees before the trailer touches the cab. Of greater concern is how close the pin box gets to the bed rails, especially if the truck and trailer are not level.
2005 Honda Gold Wing
2010 Dodge 3500 SRW
2013 Cedar Creek Silverback 35FL
mike2wheels is offline   Reply With Quote
Old 06-23-2015, 12:26 PM   #14
I was told by several dealers that it is not possible to tow a fifth wheel trailer with 5 foot 6 inch truck bed. NOT TRUE. I tow a 2014 Rockwood Ultra Light 5th wheel 8289ws. Hitch is pro series 16K THE DIFFERENCE is the Reese Revolution Hitch, works like a champ.
Bobisgolfing is offline   Reply With Quote
Old 06-23-2015, 12:28 PM   #15
We have an F150 with 6.5' box and a 32' Rockwood with a Reese Sidewinder. My 5th wheel hitch is a Reese Titan 16K. No slider hitch required as the Sidewinder rotates under the trailer and not in the bed of the truck. We can do 90 degree turns with no problems.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 06-23-2015, 12:32 PM   #16
Originally Posted by jaygeo1 View Post
I'm getting very close to buying a CC Silverback 29RE. It has the cut back front cap corners. My TV is a 2500HD, 6.5' bed, extended cab, 4x4. My question is concerning the purchase of the hitch with or without a slider. I've decided for sure on getting the B&W turnover ball system and then adding the Companion 5th wheel hitch.
I'm curious as to how many of the FR Forum members are towing without a slider using the 6.5' bed TV? I would appreciate your opinion on the slider issue now that you are currently towing without a slider. Thank You.
I have a 6.5 foot bed and slider. Got stupid one day and didn't think I would need it. Here is the results of being STUPID!
Did get lucky, didn't damage the door or break the window. No damage to the trailer. I WAS VERY LUCKY!
Get the slider. Might not need it for this trailer but if you replace the trailer you might wish you had it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-23-2015, 01:00 PM   #17
I have 29re and GMC 6.5 bed extended cab also. No slider, never a problem. Been 90 degrees or close and no problem.
clydngail is offline   Reply With Quote
Old 06-23-2015, 05:05 PM   #18
Pullrite super slider
When I was pulling my Montana 5'er with my F-250 short bed crew cab truck, I installed a Pullrite super slider. I figured I better get one that did the sliding automatically so I wouldn't forget to set it to slide when backing or turning a sharp turn.. With the pullrite I back my truck at a 90 degree right angle to the trailer and never hit the trailer or the cab of the truck.
Would not pull with short bed without slider hitch.. just my 2 cents.
bmaggin1 is offline   Reply With Quote
Old 06-23-2015, 05:06 PM   #19
bbeyor's Avatar
I have 2013 2500 6.5 bed
I pull a 2006 wildcat 5er. My TV is a 2013 gmc 2500hd crew 6.5 bed with a backrack and NO slider and I have not had any issues so far. I thought I'd have to take off the backrack but haven't needed to. If you think you're going to try to do a full 90degree turn it wouldn't make it with the rack but gets very close without a slider.
bbeyor is offline   Reply With Quote
Old 06-23-2015, 06:46 PM   #20
Jim34RL's Avatar
I always figured there are two type of truck owners who pull a 5er with a short bed box.
1. They have the slider hitch and use the slider hitch as needed in tight situation.
2. Those that don't have a slider hitch and wish they had one after they have damage the cab of the truck and trailer along with a failed rear window.
Your $$$ your choice. Enough said and I do have a slider hitch. I have had one since my first 5er purchase.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
5th wheel, bed, slide, towing, wheel
