I'm getting very close to buying a CC Silverback 29RE. It has the cut back front cap corners. My TV is a 2500HD, 6.5' bed, extended cab, 4x4. My question is concerning the purchase of the hitch with or without a slider. I've decided for sure on getting the B&W turnover ball system and then adding the Companion 5th wheel hitch.
I'm curious as to how many of the FR Forum members are towing without a slider using the 6.5' bed TV? I would appreciate your opinion on the slider issue now that you are currently towing without a slider. Thank You.
I have a slider in mine. I figured I would rather be safe than sorry. Having said that, in the last 6 years of towing a fiver, I have yet to use the slide.
I have a2500hd with the bw turn over/companion hitch, but not a silverback. We have a sierra 380bh5 and have not needed a slider, came close, but can get about 75-80deg turn. The biggest issue i see with the chevy and the bw is they have a new style base that sits up higher and allows for more room between bed rails and fifth wheel, i have the old style companion, which with our king pin box trail air rotoflex gets pretty close at times
I have a 2008 Chevy 2500HD Crew Cab short bed (6.5') and I also use the B&W turnover/companion hitch without a slider. I tow a 36BLE Forest River Cardinal and have had no issues. I will also add that I have the TrailAir package on the 5th Wheel Hitch which makes a huge difference in towing and keeping everything smooth.
We have a 29 RE and tow with a 08 Ram 2500 with 6.5' bed and no problems!
I have probably had it at 80 degrees with no problem and no slider.
Of all the things I've lost in my life the thing I miss the most is my mind!
I have the B&W with a 6.5 bed. Have pulled for 2 years. I have not been in a place that I had to have a slider yet. They do now make a slider hitch if you want. I like having a flat bed and it is easy to remove. Some people say they are easy to hook & unhook compared to some other brands.
I have a slider in my Ram and have never used it. If I ever replace it , I will get the companion. Several of my fellow campers use it in their short bed trucks with no issues.
I have a GMC 2500 CC 6' 6" box and a Wildcat 327 ck without a slider hitch. Only once did I have an issue and that was when I was making a turn pulling out of a driveway going up hill. The corner of the FW touched the front rail of the box.
2014 Wildcat 327ck
I have a Reese 16k slider, but have yet to use the slide function except to test it. With the sculpted nose of the Silverback I can turn greater than 90 degrees before the trailer touches the cab. Of greater concern is how close the pin box gets to the bed rails, especially if the truck and trailer are not level.
2005 Honda Gold Wing
2010 Dodge 3500 SRW
2013 Cedar Creek Silverback 35FL
I was told by several dealers that it is not possible to tow a fifth wheel trailer with 5 foot 6 inch truck bed. NOT TRUE. I tow a 2014 Rockwood Ultra Light 5th wheel 8289ws. Hitch is pro series 16K THE DIFFERENCE is the Reese Revolution Hitch, works like a champ.
We have an F150 with 6.5' box and a 32' Rockwood with a Reese Sidewinder. My 5th wheel hitch is a Reese Titan 16K. No slider hitch required as the Sidewinder rotates under the trailer and not in the bed of the truck. We can do 90 degree turns with no problems.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
I have a 6.5 foot bed and slider. Got stupid one day and didn't think I would need it. Here is the results of being STUPID!
Did get lucky, didn't damage the door or break the window. No damage to the trailer. I WAS VERY LUCKY!
Get the slider. Might not need it for this trailer but if you replace the trailer you might wish you had it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
When I was pulling my Montana 5'er with my F-250 short bed crew cab truck, I installed a Pullrite super slider. I figured I better get one that did the sliding automatically so I wouldn't forget to set it to slide when backing or turning a sharp turn.. With the pullrite I back my truck at a 90 degree right angle to the trailer and never hit the trailer or the cab of the truck.
Would not pull with short bed without slider hitch.. just my 2 cents.
I pull a 2006 wildcat 5er. My TV is a 2013 gmc 2500hd crew 6.5 bed with a backrack and NO slider and I have not had any issues so far. I thought I'd have to take off the backrack but haven't needed to. If you think you're going to try to do a full 90degree turn it wouldn't make it with the rack but gets very close without a slider.
