Old 12-08-2014, 05:33 PM   #1
leftyneil's Avatar
7 pin tow connector?
On the E450 2015 Forester 2501. I have checked out the 7 pin tow connector and all seems well, except I need to know is a wire connected to the electric control brake signal pin, and if so where is it, like under the dash somewere, and what pin is it?
I'm connecting my tow brake controller from my old MH to my new Forester.
leftyneil is offline   Reply With Quote
Old 12-08-2014, 06:40 PM   #2
clr
On the truck or MH plug the elect brake is the blue wire on Pin 1. When you are looking at the connector pin 1 is the first pin to the left of the notch.
clr is offline   Reply With Quote
Old 12-08-2014, 07:44 PM   #3
leftyneil's Avatar
Thanks, my other question is if pin 1 is wired where does it end up in the front of the coach so it can be connected to the controller?
Old 12-09-2014, 09:27 AM   #4
clr
If your TV is a Ford E450 as I think you are stating in your post I would say the blue wire is connected to the integrated brake controller on the dash. I would look at the back of the integrated brake controller and look for the blue lead. Then I would use the multi-meter set on a R scale to insure the continuity between the two points. Check that there is no voltage on the pin before you do this. This is based upon my F350 TV and wiring seems to change somewhat every year good luck.
Old 12-09-2014, 02:50 PM   #5
Rivnut
Rivnut's Avatar
7 pin tow connector
Then go to this website and make it a favorite on your computer, you'll always have a place to check trailer wiring.
http://www.etrailer.com/faq-wiring.aspx
Rivnut is offline   Reply With Quote
Old 12-09-2014, 02:51 PM   #6
Rivnut
Rivnut's Avatar
Trailer Wiring Diagrams | etrailer.com
Old 12-09-2014, 03:37 PM   #7
You should have a coin/storage tray or switch panel and/or brake controller above the radio and the vent to the left of the radio.You should be able to pry out the coin/storage tray or switch panel to access the trailer brake wiring.Of course if the factory brake conntroller is there,then you won't need to install your own.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 12-09-2014, 04:36 PM   #8
leftyneil's Avatar
Thanks grizz, what's the trick to removing the coin/storage tray? I tryed to pry if off but worried I will bust it. It's plastic
Old 12-09-2014, 05:43 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
Great web link. Thanks!!
donanddona is offline   Reply With Quote
Old 12-11-2014, 03:40 PM   #10
The shop manual indicates to use a small screwdriver and pry from the right side of the tray/coin holder.
09grizzly1
09 Grizzly 700 EPS
Old 12-11-2014, 03:42 PM   #11
leftyneil's Avatar
09grizzly1
Got it Griz, Thanks
