Old 08-23-2012, 01:12 PM   #1
Camper Less Camping
Cajun Po-Boy's Avatar
7 Way Plug Install Inside Truck Bed
Ordered the wire harness for my truck to install in a week or so...looking for any suggestions on the placement inside your bed.
I've read that the best area is between the fender and tailgate on the driver's side...anyone have suggestions on Do's or Dont's welcomed
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-23-2012, 01:15 PM   #2
TURBS's Avatar
Chevrolet's are drivers side between wheel well and front of bed.
Harness is already there on the hd's.
I have mine over the tailgate and plugged in normal as to not catch on anything in bed when turning.
Old 08-23-2012, 01:21 PM   #3
B47
That is where our dealer that installed our FW hitch placed mine and I couldn't be more satisfied with it. After we are hooked up, I can secure my breakaway switch cable and insert the plug before lifting up the tailgate.
One thing to remember also - my Ram 2500 came with a 4 prong plug installed in the rear bumper next to the license plate holder - so do not disable the 4 prong plug if you have one. You don't know when you might need it.
Old 08-23-2012, 01:24 PM   #4
Here's where the dealer put mine and I like it just fine. Easy to get to and out of the way. Works perfect with the tonneau cover on while towing.
Old 08-23-2012, 01:28 PM   #5
On most Chevy's, left rear (driver's side), stake pocket, is hollow, and when you remove the rear tail light, you can see straight through to the ground. Use a bi-metal hole saw to make a round hole. Don't go too large, just enough to get the plug in, and leave room for the mounting screws to catch some metal. You only get one shot at this. This gets the plug, in the bed, accessible, but very out of the way. Looks very professional also. Pictures above, somebody typed faster than I did.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-23-2012, 04:02 PM   #6
golfmedik's Avatar
I have the Bargman 90* plug in the same place on my Chevy and my Ford. Here is a pic of the Ford location.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 08-23-2012, 09:26 PM   #7
Oklahoma Proud
MillerTime's Avatar
If I could make a sugestion. I work as a GM collision tech and I would STRONGLY recomend that a plug not be installed in the rear tailgate post as pictured above. Those tailgate post make up 100% of the structural strength of the rear if the bedside. I hole big enough to install a plug would weaken this post probably 30% or more. Also any kind of quick connect on the wiring allowing the bed to be removed without wires would help us techs a lot. Most of the time we just have to cut through all the wires and then but connect back together. That us about the only way we can know it is back to the way the customer had it as many installers do not use correct colors on wires to plugs. I recommend using an "extention cord" type set up if not wired factory for a second plug and just plug the male end into factory plug and mount the female where desired. Easily reversable and will save tons on costly electrical problembs.
Old 08-23-2012, 09:28 PM   #8
Oklahoma Proud
MillerTime's Avatar
Sorry the pic directly above last post is NOT what I was talking about. The inner bedside us a very good location, I meant the pic further up the post
Old 08-23-2012, 10:16 PM   #9
Don't know where you get the 30% reduction in strength, but be that as it may, there is no load being put on the post from anything but from slamming the tailgate and holding it closed. Also with the tailgate closed there is no side load. For the hole to have a detrimental effect, there would have to be a fore & aft load which there are no such loads. I can see where the electrical connection would cause you some headache, but all you have to do is pull the female plug out, unhook the wires, tape the ends and pull them back and down the the rear.
Old 08-23-2012, 10:53 PM   #10
Oklahoma Proud
MillerTime's Avatar
These are just sugestions and anybody can do as they wish. I have to think of structural integrity and liability in everything that I do. On the wiring, a simple quick connect would be free to disconect a hard wired plug incures a 1+ hr charge most times.
I have worked on collisions where 5ers have been driven into the tv cab from a rear hit and also tv rear ending another vehicle and the momentum of the trailer keeps going while the tv has come to a stop. Also seen many beds, frames and hitches mangled from blow outs uneven terrain and sudden stops or running off the road with a load. That said any extra structural components or reinforcement can potentialy save the lives of passengers in the event of the unpredictable.
bed
