Old 05-01-2016, 10:56 AM   #1
'97 Ford Explorer 2wd Manual Toadable?
We are driving our 2011 Sunseeker 3170DS from Texas to Alaska this summer. Wasn't planning on bringing a toad, but am starting to think it may be a good idea if I can do it fairly painlessly. I've got a 1997 ford explorer 2wd manual transmission that I drove for years and now is used to store cattle feed, teach kids to drive a standard, and provide a backup vehicle when something needs to go to the shop. In other words, it is a fairly disposable vehicle that runs great and, aside from a broken odometer, a driver's side door that won't lock, and a lot of sun damage, is mechanically sound with good tires. It also has a roof rack that would let me take my canoe along.
I've been looking around for a few hours this morning for an indication as to whether it can be towed 4-down dinghy style, and I can't find anything directly on point. The manual says you can't tow it, but I'm not sure the manual differentiates between the automatic versions and the standard transmission that I have.
Does anyone have any experience using an explorer from this era with a manual transmission as a toad? If so, do I need to make any modifications before hooking it up? I'm assuming I will need to install some sort of supplemental breaking, but I didn't want to start figuring that out until I understood whether this vehicle would make a good toad or not.
Many thanks!
Andersunseeker
Andersunseeker is offline   Reply With Quote
Old 05-04-2016, 04:28 PM   #2
Tfort's Avatar
Most manual transmissions are flat towable unless they have a separate oil pump that is driven off the input shaft. If I remember correctly that one does not and should be towable. It has been a long time since I have been in one of those transmissions so don't quote me on that. I would keep researching to make sure.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 05-04-2016, 04:40 PM   #3
Tfort's Avatar
I should have looked this up before posting. The 1997 explorer has the MD05 manual transmission which is he same al the way up to 2000 where I found a towing guide. It states in the guide that it is flat towable. I screen shot the page for you. Click image for larger version
Name:	ImageUploadedByForest River Forums1462398027.715691.jpg
ford, manual, toad
