Old 03-30-2016, 06:44 AM   #21
Had to replace my lines on a 1/2 to chevy lines rusted out no breaks
wire1946 is offline   Reply With Quote
Old 03-30-2016, 09:10 AM   #22
Kenny kustom's Avatar
99 through 06 GM Rusted brake lines
I flush mine at 30km..
Mercedes recommends every 10k miles.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 03-31-2016, 08:38 AM   #23
I replaced my lines yesterday with a prebent stainless set. All the lines were internally in new shape except the first 3 inches in front of the rear axle rubber line where it burst. There is was flaking rust nearly to the inside of the line. It is an exterior line problem not a fluid or moisture inside the line issue. No doubt they are not able to cope with salt. Replacing them from reading the truck forums looks a nightmare but reality is not that bad. Cutting the lines one at a time then removing with a socket instead of a line wrench. Installation with a line wrench. Removing the old rear line before feeding the new one over the gas tank was the only tough part. It's held by plastic clips to the top of the frame rail. Hour and a half to get the old line out. 10 mintes to put the new one in and no, it's not clipped into the plastic clips short of bed removal.
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
Simplewon is offline   Reply With Quote
