Old 09-25-2015, 10:20 PM   #111
lynn brownlee's Avatar
A valve is closed , they were patented and called a jake brake, the patent ran out and now any one can use them in a deisel engine, the turbo creates more compression due to a valve closing creating more back pressure, same way the pressure from the exhaust is boosted by a turbo to force air and fuel into the combustion chamber, so the exshalts valve is closed. A none turbo deisel engine can work by closing a exhaust valve. Diesels engine have tremendous compression compared to a gas or ringed engine. Gas engines do not have enough compression and could not use exhaust pressure to break a vehicle effectively.
lynn brownlee is offline   Reply With Quote
Old 09-26-2015, 07:04 AM   #112
davel1971's Avatar
What is a ringed engine?
David & Lynn
Old 09-26-2015, 07:19 AM   #113
B and B's Avatar
I don't know, I don't own a Chevy or never will to tow with. I do know the F 150 Ecoboost in tow mode and running cruise will slow you down without touching the brakes. My 09 F 150 with 5.4 Triton in tow haul mode did not do this.
The Chevy's are made in Mexico as well.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-26-2015, 07:27 AM   #114
davel1971's Avatar
If you think Ford is USA loyal, someone lied to you. Plenty of factories there, and more being built right now. Nothing is 100% made here. Parts and sub-assemblies come from everywhere. Just buy what you like.
David & Lynn
Old 09-26-2015, 08:20 AM   #115
CWSWine's Avatar
So the Ford F150 does works the same as Chevy 1500. It called Basic Cruise Control/Tow Haul Mode by other manufactures. Ford Making Up Terms Again.
You do know that Toyota has the most cars/trucks with the highest Made In American list.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-26-2015, 08:59 AM   #116
B and B's Avatar
Hmmm Yes i did. We have a Two Toyota plants with 20 minutes of where I live. GMC Acadia and Equinox (Used to be Cami GM/Suzuki partnership) plant 30 minutes away and Ford and Honda 60 minutes. A lot of auto manufacturing here!
Back to the thread.
Doesn't matter what it is called, assists with engine braking and saves linings.
Old 09-26-2015, 10:37 AM   #117
drittal's Avatar
I owned 2 EB F150 and that little 3.5 needed dynamic cruise just to hold itself back when empty.
drittal is offline   Reply With Quote
Old 09-26-2015, 11:07 AM   #118
Tonkatoy77's Avatar
Your post doesn't make any sense. You do know there is a difference between an exhaust brake and an engine brake right?
An engine brake, which is called a Jake brake, is a solenoid on top of the exhaust valve. During the compression stroke the solenoid activates and pushes the exhaust valve open. The term "Jake" came from the manufacturer Jacobs. There are other engine brake manufacturers like Pac Brake, but Jacobs is the most popular.
An exhaust brake is a system that puts a restriction in the exhaust system. Before the variable vein turbos company's like Banks were building an exhaust brake that goes in the exhaust pipe. It was just a flap attached to an actuator. When you turned it on the flap would close, causing a restriction in exhaust flow. Same principle with a variable vein turbo. When you activate it, the veins in the turbo close, causing a restriction in the exhaust system.
I hope all this makes sense. Lol
Also, I'm not sure what you are talking about when you say a "ringed" engine? Are you saying a diesel doesn't have piston rings?
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 09-26-2015, 11:17 AM   #119
deebarjay's Avatar
he'll only buy new
the new jacked up alum F150's with heavy tow are just about as spendy as an F250 with the 6.7.
2008 F250 6.4 diesel with 50 gal aux tank towing a 2015 Rockwood 2109s Minilite.
2015 Miles and nights
10040/31
2016 miles and nights
feb. 380/7......march 540/3
deebarjay is offline   Reply With Quote
Old 10-04-2015, 05:08 PM   #120
LTnTN's Avatar
Originally Posted by BamaBob View Post
I would respectfully disagree
Up and down the mountains no problem (helps that the EcoBoost has a built in engine brake )
Me too ... No issues whatsoever. I'm loaded to about 10% below max spec, and the truck just sings.
2015 Flagstaff 8528RKWS
2013 Ford F-150 Ecobeast
LTnTN is offline   Reply With Quote
5er, truck
