Old 09-21-2015, 11:50 AM   #81
CWSWine's Avatar
I was checking the GVWR on 2015 F150 and noticed the highest rating on Ecco was 7850 lbs with 3000 lbs CC that means the truck can not weight more than 4250lbs. Then I pulled my weight ticket when I weight my F350 empty ready to tow and it 8200 lbs. That's huge difference of weights between the two trucks.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-21-2015, 12:24 PM   #82
dcheatwood's Avatar
If a picture paints a thousand words . . .
Rockies , Smokey, Ozarks. Colorado, Wyoming, Montana, new Mexico, Arkansas, Missouri, Tennessee, Virginia, and on and on. A TT, 2 fivers. Never a hick up from the halfton. Only problem since 2005 was blowouts on the fifth wheels.
ID:	89442   Click image for larger version
ID:	89443   Click image for larger version
ID:	89444   Click image for larger version
ID:	89445   Click image for larger version
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 09-21-2015, 01:48 PM   #83
leefl's Avatar
Originally Posted by another_newfie View Post
leefl, very well put. I didn't mean to come off all confrontational, but in re-reading my post I did..
My truck is a supercrew (my previous truck was a shortbox supercrew and I'd never own another). I need the LB and Supercrew. It has BOTH the HD Payload and Max Tow.
Ironically I was in a similar position and got my order in just before Ford closed on the 2012 production run (I had done over a year of research and pulled the trigger at pre-determined date).
You are quite correct that my pin weight is less than yours and that is no accident either. A LOT of background went into the combo that I have. It was all pre-planned and it has worked out very well. Most though don't do anywhere near the amount of legwork we did. The end result is a combo that doesn't work.
Unfortunately with my specific floorplan requirements for the fifth-wheel (small bunk-room, preferably with second toilet, but without taking up too much space from living area), meant that the Rockwood 8281WS was the perfect choice for us, but has the heaviest pin weight of any 'ultralite' I've seen.
I could barely have scraped by with your spec truck, after adding the hitch weight, 2 adults, 2 teenagers, etc ... but it was not to be.
That being said, although the ride is not as smooth (smoothest ride of any truck I tested was the new Tundra, but it was nowhere near up to my towing needs), and the mileage (when not towing) certainly nowhere near as good as the F150 ecoboost, I do still really like the F250.
It's certainly huge in comparison to most "half ton" trucks
(tho' the inside is not that much different to the F150 supercrew)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 09-21-2015, 01:57 PM   #84
leefl's Avatar
Rockies , Smokey, Ozarks. Colorado, Wyoming, Montana, new Mexico, Arkansas, Missouri, Tennessee, Virginia, and on and on. A TT, 2 fivers. Never a hick up from the halfton. Only problem since 2005 was blowouts.
Very nice indeed.
TBH I'm surprised the Tundra is up to the job, since when I looked (only at the longer crew cab), the capacity wasn't that great.
I'd be very interested to hear any feedback on the AirLift's.
TBH the ride on the F-250 is probably worse when not towing, and slightly helped by the weight, but I'd be interested to know if they've helped with the ride on your Tundra. (payload capacity isn't an issue for me per-se)
Where does the compressor install ? (I have upfitter switches in the F-250, ready for something like that, but want to try to keep the bed clear)
Old 09-21-2015, 02:00 PM   #85
drittal's Avatar
Have you guys with half tons and large TT/TH or 5er put it on the scale?
As I pointed out before, my 3/4t with a 30FBW (~1400lb mfr tongue weight) came in at 9200lbs on the scales. So misc items and normal gear plus wife and 2 kids and 18lb dog added another 800lbs !!IF!! I am to believe both Ram and FR's weights... which I dont.
The only true way to know is to hit the scales.
drittal is offline   Reply With Quote
Old 09-21-2015, 02:02 PM   #86
drittal's Avatar
Another thing to factor is some truck mfr's have in the past done things like removing bumpers, spare tire, tail gate to get the big 1/2t towing and payload #'s.
Old 09-21-2015, 02:52 PM   #87
drittal's Avatar
Top of the world. Did you take that 5er down bear tooth pass? That had to be tight if you did. We were there this summer on MC and I remember a sign near there recommending an alternative route if over 35ft total length.
Old 09-21-2015, 02:59 PM   #88
dcheatwood's Avatar
Yes I did. Without knowing about it until too late. Left Yellowstone thru northeast gate. Beautiful drive. No traffic, no ice or snow and no problems. Stopped for fuel when we came down the other side and a guy asked "you didn't just come down the beartooth in that, did you?" I said yeah why? He just took a walk around the truck and fiver shaking his head and said, "unbelievable."
I didn't realize what a big deal it was until I started telling this store and folks found it hard to believe. 😁
Pulling and stopping is never an issue with the 5.7L. It's just the pin weight in the bed of the truck that concerns me.
Old 09-21-2015, 03:05 PM   #89
dcheatwood's Avatar
Told my wife when we were coming down that'd be a great ride on a bike. Bet you enjoyed it.
Old 09-21-2015, 03:08 PM   #90
PhoneDude 8289's Avatar
Took the Tundra and 5r to the scales, here are the numbers.
Tundra without trailer 6,400#. Includes DW, myself, a 60# Boxer, a 6#Yorkie, Hitch and a 3500 watt generator behind the cab.
Tundra and 5r weighed in at 15,080. Tundra front axel 3,400#, Rear axel 4,140, Trailer axels 7540. No food on board the 5r, everything else ready to go. Yep I'm over payload, dont tell the weight police. With air bags it all rides level. A good break controller and 10 ply tires a must.
My previous 5r was 1200# heavier, Tundra did well with it also.
Sad to say that since these weights were taken we lost our Yorkie and Boxer 6 weeks apart.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
5er, truck
