Old 02-01-2019, 12:52 PM   #1
Ejs4029's Avatar
A Capable Truck ?
Well I was reading the thread about ‘Pulling a 5er with a half ton’ and it got me thinking…I tow with a 2015 RAM 2500 Diesel payload is on the light side at 2257lbs I’m towing 8K loaded with close to 900lb tongue weight all my weights are well below the trucks capacities and have been CAT scales to certify.
Ok so here has been on what’s my mind and that is what makes a truck more capable ? The F150 with the HDPP seems impressive in getting you over 2500lbs in payload shoot I guess there are some F150’s out there now that are over 2000lbs payload now…Does that make it a more capable then my ¾ ton RAM with 2257lbs and the Cummins with 370 HP and 800lbs of torque ? I suppose there are some 5th wheels it can tow that I would be over weight in payload with the RAM. I think with my limited knowledge on the F150's I would be able to bumper pull more weight though ?
Don’t get me wrong I am very happy with my truck and towing experience in fact I'm not sure it can get any better in my situation and maybe I’m trying to compare apples to oranges ? What do you think ?
I was at the RAM dealer recently looking at some other higher end trim model 2500’s with diesels and the payloads on them were less than 1,900lbs which rules out a lot of 5th wheels so what is the indended market for them so to speak ? Heavier bumper pull trailers of all sorts ?
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 02-01-2019, 03:02 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Just for grins my 2500 6.4 has a 3200# payload and a 13700 tow max. The more options you add the less payload you get. Mine not bare bones and has as many option as my Chevy did.
The only thing you get better is fuel mileage but loose payload. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 4
Old 02-01-2019, 03:22 PM   #3
clarkbre's Avatar
Seems that lately, the "truck capability" threads have been popping up more and more. I think the weather and the fact we're all thinking about towing our trailes on vacation has something to do with it. Honestly, everyone has so many "if this, then that" scenarios.
My short list of conclusions are as follows for the average family, crewcab truck:
1. 1/2 tons equipped with good towing packages should keep under 7000 lbs and 24' model trailers. This keeps them within specs on weight and they are able to control and stop the trailer correctly.
2. 3/4 tons should be considered "heavy 1/2 tons". With [B]bigger brakes and stouter chassis, they are capable of handling bumper pulls and 5ers up to 10,000 lbs fairly easy. They should also be gas fueled only...no diesels...ever. While they are often much more equipped to handle larger trailers and have bigger payloads, a diesel motor in the nose will eat up that payload dang near back down to 1/2 ton status.
3. 1 tons should be fueled by gas or diesel but the obvious preference would be diesel. The power makes perfect sense for this size truck. With the larger payload, a SRW would easily handle a 5er up to 15,000 lbs with a 20% pin weight. Anything over that, you're in dually territory.
4. Visiting the scales should be required prior to signing the dotted line!
I know most will argue that my conclusions are probably bogus; however, this is a very common trend that I see on the forum here.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is online now   Reply With Quote
Old 02-01-2019, 03:23 PM   #4
Ejs4029's Avatar
Ok RJD with that being said your towing in the 9K ballpark right ? An F150 with the HDPP would have been able to handle your trailer right ? Would you be comfortable with that ? if not why if it all was within it's capacity ?
I'm not so sure it's just better fuel mileage I'm getting with the Cummins compared to the 6.4...But that is another discussion
TST 507 TPMS
Old 02-01-2019, 03:28 PM   #5
clarkbre's Avatar
Originally Posted by Ejs4029 View Post
......I'm not so sure it's just better fuel mileage I'm getting with the Cummins compared to the 6.4...But that is another discussion
MPG is such an insignificant number....
Whats the actual cost per mile of a diesel vs gas? Not fuel...actual cost.
They may get better mileage than an equivalent gas fueled truck; however, they are more costly in every other way:
1. Purchase price
2. Fuel (Gas is 2.69 gal, Diesel is 2.99 gal currently in WA)
3. General maintenance: Diesels take more oil, bigger oil filters, fuel filters, DEF
4. Repair
While they may get better MPG, its very easy to argue that for 250k miles, a gasser is overall the lower cost truck.
Old 02-01-2019, 03:33 PM   #6
Grammar Pedant
67L48's Avatar
It's very important that you start with a definition of "capable." Depending on that definition, the answer to your question varies significantly.
Yep, there are lots and lots of 1/2 tons with higher payload ratings than 3/4 tons. Does that make them more capable? Maybe. Maybe not.
You also need to appreciate that you're evaluating these trucks through a lens of RV usage. That's a minority of truck applications. So, the utility of these trucks isn't solely measured by their abilities to lug around a 5th wheel.
Current RV: 2018 Rockwood Mini Lite 2504S
TV: 2019 F-350 Lariat 4WD CCSB 6.7 PSD, 3,591 lb payload
67L48 is online now   Reply With Quote
Old 02-01-2019, 03:34 PM   #7
BandJCarm's Avatar
I'm coming to hate all truck threads. So much "stuff".......
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 02-01-2019, 03:37 PM   #8
There’s much more to towing stability then a payload rating. The extra mass of your truck over one that weighs 5500 lbs makes it a far better choice.
Dustyhd is offline   Reply With Quote
Old 02-01-2019, 03:38 PM   #9
Ejs4029's Avatar
So your basically saying there is no practical purpose for a 3/4 ton with a diesel because of payload constraints thus regulating it to a heavy duty 1/2 ton so to speak....I personally preferred the diesel option over the increased payload of the 3/4 gasser for a variety of reasons
TST 507 TPMS
Old 02-01-2019, 03:44 PM   #10
clarkbre's Avatar
Congrats?
truck
